This is my first post on here but I've been lurking awhile. I figured I'd share my build since I got most of the ideas and info for it off here. I retired from a career that included everything from Navy electronics, working in a semiconductor FAB to critical power in hospitals and data centers. The electrical aspect of an e-bike is very straight forward to me, the bicycle side of things are new. Since I don't know any better I chose to approach it from motorcyclist POV, this build might not conform to some of the norms.
I also happen to live right next to a huge chunk of desert with literally a 100sq miles of trails, dirt roads, dunes and plenty of sand. Much of it's too soft for a regular bike with narrow tires and even a 3" tire would be allot of effort sometimes. I normally ride dirt bikes, dual sports and adventure motorcycles, bicycles are a new area for me but I'm right at home on 2 wheels.
This was going to be a budget build so it ruled out the the higher end bikes and a used Fat Tire bike is pretty rare around here. With that in mind I picked up a 35# alum framed Dolomite from Wally world. I know, it's a big box store and all that entails, I figure I can address the bike's weak points as it becomes necessary. Goal was cheap, light weight (within budget constraints), mid drive and a decent battery. Where I'll be riding nobody cares if you spin the back wheel or how many watts your motor is.
Fresh out of the big box
The ergos on this bike weren't cutting it for me, I didn't care for the mtn bike bars nor the seat. Those got swapped out which improved the riding position and comfort significantly.
Next it was over to Luna for a 120mm BBSHD and Eggrider display. I picked up a 52V 20AH triangle battery and 4A charger online. The motor install was a breeze, it took longer to make the wiring nice then it did to swap over the components. I've been doing my homework and the build included a shift sensor.
The battery fit the frame like it was made for it. The bottom bracket is 120mm so the motor fit nicely w/o any spacers.
The chain line wasn't bad but could be improved and I knew it needed lower gearing, I needed to see what I ended up with before ordering anything. It'll be getting a Lekkie 40T with the 20mm offset and it's associated motor cover, the cassette is an 11/34 8 speed. The Lekkie will be a hit to the budget but I ride enough motorcycles that I know I want the drivetrain to work correctly w/o any compromises if possible and I know correct gearing makes all the difference off road.
It gets all the gears now and shifts normally so I'd like to keep a similar chain line, the Lekkie should improve that a couple MM compared to the stock chainring and give it some decent torque while keeping the motor spinning up in it's happy place.
It doesn't look like it but there's 6mm of clearance between the flywheel and the chain stay. The 46T chainring is a little closer to the chain stay but there's room to fit the 40T in there. Everything fit surprisingly well.
So far I'm pretty happy with the build, no drama. Eventually it'll get some inexpensive suspension forks, the better gearing and a decent suspension seat post. There's likely going to be some weak points but I'll deal with those as they come up. I got everything online, had it built 2 weeks after ordering the first part and I'm at $1700 w/o the future upgrades. It rides and runs nicely for being an inexpensive bike, this build couldn't have been easier.
Thanks for reading.
Thanks for reading.
