Built this 12 years ago...Time to upgrade
    I have a lot more to post, stay tuned..... wow did it finally happen... able to post Thanks
    I will be posting all the details about this, when I first built it, it had 2 55 amp hour lead acid batteries,
    they weighted a little over a 100 lbs, just put two 35 ah lipo batteries 15 pounds... 24 volt...​
    Two weeks ago I ordered new batteries 50Ah Lipo4.. cylindrical... 8 of them, there cells are HUGE they are 8 inches long and 2.5 inches diameter..
    they will stand upright around a mount I built out of 1/4 inch ABS..... A 200 amp BMS will sit in the circle of batteries...
    Click image for larger version  Name:	image.png Views:	0 Size:	484.0 KB ID:	167755
    Pic of BMS and battery holder.... The BMS is a 200 amp....
    Click image for larger version  Name:	image.png Views:	0 Size:	2.33 MB ID:	167756
    Just put two 35 ah lipo batteries 15 pounds... 24 volt... I just want more power that is why I will be changing
    these 35 Ah to the 50Ah cylindrical..​ batteries... actually no really more power, more for the looks, the wow factor...
    Click image for larger version  Name:	image.png Views:	0 Size:	3.48 MB ID:	167757
    This is the original build with the two 55Ah lead acid HEAVY
    Click image for larger version  Name:	image.png Views:	0 Size:	535.3 KB ID:	167753
    A 300 amp Kelly Controller The Motor is a NPC 3.5 Hp up to 200 amps....
    Click image for larger version  Name:	image.png Views:	0 Size:	512.7 KB ID:	167758
    My display shows voltage and current..
    Click image for larger version  Name:	image.png Views:	0 Size:	449.3 KB ID:	167759
    Nice build. What kind of motor is that?
    https://www.google.com/search?client=opera&q=NPC+4200+Black+Max&sourceid= opera&ie=UTF-8&oe=UTF-8
    NPC 4200 Black Max not sure if that link would be any good....
    Click image for larger version  Name:	image.png Views:	0 Size:	67.7 KB ID:	167856
    Click image for larger version  Name:	image.png Views:	0 Size:	0 ID:	167857
      The hardest part is waiting for my batteries from China, ordered on June 6th, I will be getting two of these total 8 batteries....
        I did put a new battery charger on my bike for the lipo4 batteries
        29.2V 15A LiFePO4 Battery Charger for 8S 24V LiFePO4 Battery with Cooling System Safety Protection​
