Just finished building an e-bike out of my old Cannondale F4 "Caffeine" 26" hard tail. The BBSHD went right into the 68mm bottom bracket with no issues at all. The stock gear provides a good chain line with no need for spacers. The 42t Luna gear did not line up. The 52v Carbon Shark battery fits in the frame with room to spare. It took me less than 2 hrs to complete the project: it was that easy. It climbs 24% grade at 15mph. Top speed about 36mph on the flats. So much fun to ride around!
Cannondale F4 "Caffeine" with BBSHD
Nice, what size is the frame and approximate year of manufacture.I just love these old bikes, so easy to convert with the standard BB., possible to have a larger image as I would like to post it here, http://electricbike.com/forum/forum/...ible-pictorial
The installation on a Cannondale F4 needs spacers because the bottom bracket is a 68mm shell and the motor is 73mm. Also, the back of the gear cover does not clear the chainstay. Otherwise, you have 5mm slack and the motor will not tighten. The original bottom bracket is a Shimano Octalink BB-UN26 Square taper.
I built a BBS02 on a 1998 F700 that worked very well. only 43 lbs with a 13.5 MaH battery. It needed a shim in the chainring (52T Lekkie) but otherwise was a straightforward build. I also had plenty of stopping with the V brakes and upgraded pads. The battery fit fine on a cannondale 15" frame (16" at top of seatpost). I have since upgraded to an anthem frame and a BBSHD, which is sort of better, though my cannondale felt like a fast bike. The 53 LB Giant feels more like a hybrid motorcycle.
