A few highlights & thoughts. I built this bike to be used as an all season cruiser. I went with the 15†frame so my wife could also use it. I chose the single speed because I planned on converting to the Shimano 3 speed IGH. Since I plan to occasionally lock it up at the mall, Iâ€m also adding a few safety precautions/deterrents. I made a lockable battery tray (see photo), and when the weather warms up, I will spray the back part of the frame a vibrant orange.
Bike mods include a 120mm x 25degree stem, Fizik Nisene bike seat, and flat pedals. I’m staying with the stock brakes, and swapped in the Bafang ebrake levers. I also ordered a pair of minibike/dirtbike plastic fenders measuring 4.5†wide x 23.5†long for more tire coverage.
Shimano 3 speed IGH install. I had the lbs assemble the wheel. I also needed a disk brake adapter (6 bolt to spline) and a new chain. The total came to $150.00 for parts and labor. I thought the installation would be straight forward, it wasn’t. I had to grind down a small section of the frame (see photo) to get the rear shifter housing on the locking bolt. I also added a washer between between the rear caliper and frame to center the disk in the caliper.
I went with the BBSHD 73mm-100mm bottom bracket, and will be adding the 42T Bling Ring to move the chain ring in. The stock 46T also works. Everything is finished on the bike, just waiting for the Bling Ring and the electrical connectors I forgot to order.
I read a few reviews on fat tire bike pumps. The best pump only needing 350 strokes to inflate the tire. That convinced me to go with the Innovations Monster air chuck & 45 gram Co2 cartridges.
I’ll post some photos as I get further along.
