Recently finished converting my wife's Specialized Myka using the BBSHD. The installation was pretty straight forward with no issues. That being said, the biggest pain was mounting the brake sensors to the stock brakes. I finally drilled and tapped a 3mm hole in the brake handle and attached the magnet using a screw. I used a 2 part 5 minute epoxy to attach the sensors to the the lower section of the hydraulic fluid housing. I also replaced the Shimano thumb shifter with a Sram twist shift. The Mighty Mini battery is mounted behind the water bottle cage.
Parts used:
BBSHD (68-73 bb)
color display
Shimano E crank arms
36T bling ring
Mighty Mini cube 30Q 6ah battery.
Parts used:
BBSHD (68-73 bb)
color display
36T bling ring
