For this build, I converted my Utah Trikes Annihilator X90 (Catrike Expedition frame) into an e-X30 using a BBSHD kit from Luna Cycles. You'll understand the naming reference shortly . . .
The donor tadpole trike started as a Utah Trikes Annihilator X90:
For the Luna Kit, I went with a BBSHD kit including:
Now, in terms of the naming . . . replacing the front FSA Triple crankset with the BBSHD meant I was going from 90 gears to 30. Not a big deal given the power I would have from the motor. Given that instructions exist for mounting a BBSHD kit, I'm not going to repeat those here, but rather call out some trike specific stuff of my build . . .
Let me know what you think!
- Catrike Expedition frame
- FSA Gossamer Triple Crank
- Sturmey DualDrive 3 speed rear hub with SRAM X7 10 speed cassette (30 speed total)
- Schwalbe Big Apple 24x2 tires on the front and 28x2.15 tire on the back wrapped around Velocity rims
- Terra Cycle Elite Power Idler
- Avid BB7 Disc brakes on the front
- Utah Trikes custom seat mesh
- Double Mirrycle mirros
- BBSHD - 68-73mm
- BBSHD Aluminum Chainring Adapter and 42T Sprocket
- Luna Full Color Display DPC-750c For the BBS02 and BBBSHD
- Bafang BBSHD and BBSO2 Universal Thumb Throttle
- Bafang BBSxx Brakes Pair - Silver
- Speed Sensor
- Gear Sensor
- 48 SHRK GA (I already have two chargers from my previous build)
- Luna Cycles Cyclops LED Light
- Luna Rear Light
- 2x - Bafang Gear Sensor Extension Cables (1 for the gear sensor and one for the second brake handle)
- 2x - Bafang 24" Speedo Extension Cables
- I started by removing the seat mesh and also removing the chain to soak it in degreaser to clean it while I did the rest of the build. The seat mesh definitely gets in the way of the wiring.
- I then removed the front derailleur and front shifter as shown in the photos. On the X90, I had a bar end shifter for the front, so removed this to allow for the placement of the console mount.
- Next, I removed the front crankset and replaced it with the BBSHD. I used one shim spacer to ensure a biting grip into the bottom bracket. A word of caution here . . . as the motor mounts on the top of the boom, it wanted to swing down until I secured it. The weight of the cables was pulling it back around, so I secure those with a zip tie until I could tighten the mounting nuts. I also placed a small piece of 1/8" thick rubber between the motor and the boom extension to prevent rub at that point.
- With the motor now in place, I swapped out the brake levers for the Bafang ones. Not a big deal, but a little more involved on a trike than a normal bike.
- I put XT60 connectors on my lights, battery cradle, and motor for power connections. This then allowed me to use a splitter at the front of the bike to connect the light wires to the motor wires. I did the same in the rear with the rear light and the battery cradle. I then just needed to create a single extension cable with XT60s on both ends to connect the two splitters. Power wiring now done!
- I mounted the speed sensor to the existing mount near the front left wheel. This still required two speedo extension cables to reach the connector coming from the controller.
- The wire for the left brake cut-off connected directly to the console harness, but I needed an extension cable to reach the right brake wire.
- I also needed an extension cable to reach the gear sensor which I mounted close to the rear cassette derailleur. I did not put a second sensor on the Sturmey IGH as I don't plan on using that while pedalling. I also understand from some of the forums that it is best to keep this in the middle gear when using the motor.
- I programmed the controller using a modified version of Karl's Secret Sauce. I'll add those settings to a reply to this post.
