It's funny in an ironic sort of way, that circumstances conspire to send you down a path that with any other sane thought process, you would never venture. There really isn't any other way I can explain fitting a BBSHD and battery to a Giant Anthem Advanced 29er. That's the carbon frame model. I'd been reading the post about the Swiss engineer that had assembled a light weight carbon mountain bike and this coincided with an advertisement on my local site, for a second hand Giant Anthem Advanced29er for the very reasonable price of $2k Aus. I've been commuting on my current Anthem aluminium model for over a year and haven't so much as thrown my leg over another bike since. My only niggling regret was the fact it was a base model Anthem and didn't have all the bling of the XT components. In a moment of tempory insanity, buoyed by the enthusiasm of my recent read, I purchased the bling laden Anthem Advanced. Then the enormity of what I'd done started to set in. My original Anthem project had been a little challenging but all the answers were available and Luna even offered the aluminium bottom bracket spacers. The carbon frame of the Advanced presented a few more issues.
First issue was mounting the battery. I've never been a fan of simply bolting the battery pack to the drink bottle cage and in any case the space available on the bottom tube was extremely tight. The battery would only just fit between the shock absorber and the upper cross tube. The only option I could come up with was the adapter plate and drill and insert a third 5mm rivet nut in the carbon fibre. With shaking hands I drilled into the nice clean carbon frame and gingerly squeezed in the rivnut. Worked a treat. A piece of 50x3mm aluminium flat then made the base of my adapter plate. The plate attached to the frame then the battery screwed to the plate. Just had to notch out a couple of spots around brake cable lugs.
Next issue was the bottom bracket. The Anthems uses those 41OD bearings. I started out with one of Luna's generic aluminium spacers then turned down a shoulder so it would fit through the bottom bracket. Then turned up a corresponding bush for the drive side. The whole bottom bracket was machined to an interference fit and pressed into place with 680 Locktite. At this point there was no turning back. The Advanced would never again be a conventionally powered cycle and possibly only even odds of being a ebike at this point.
Now I had conveniently overlooked the fact that I was relying on the locktite to prevent the whole aluminium assembly from ever moving or rotating in the bottom bracket. A post for assistance was answered by JPLads who quite correctly pointed out a requirement for torque reaction bracket to compliment my press fit bushes. The bracketing solution I eventually settled on was to fit a 5mm bolt through the bottom shock absorber mounting pin. This also required a .5mm walled internal brass spacer to take up the bolt slack, then a modified steel mounting bracket on the non drive side and a curved aluminium bracket on the drive side.
I've only done about 300klm on my new ride, but honestly, it's got to be the best commuter ride around. The lighter weight really makes a difference and the suspension is a dream. I might even have to change my moniker to Soft Tail.
It's been an exercise outside my comfort zone, putting this one together, but if you're up for a build challenge, it's achievable, the end result is most definitely worth it.
