Decided to build a Surly ECR with all the parts left over from my Electra Lux Alloy Cruiser 29+ custom build; that I eventually returned to original and sold off. Basically all the parts except the frame and fork will be transferred over to the ECR: Bafang BBS02-B 750W/48V mid-drive with color display and 42T Lekkie Bling Ring, Velocity Dually wheelset with Sturmey-Archer (S-A) 5-speed IGH laced up with DT Swiss Alpine III spokes for good 230lb. Clyde rider strength and Shimano Deore front hub, Surly Extraterrestrial 29 X 2.5 tires mounted up tubeless, Tektro HD-E350 hydraulic brakes with play-n-play Bafang power cutoffs, Thudbuster L-T seatpost with ISM Urbaine saddle (NOTE: The L-T wouldn’t fit with my leg length, so I ended up using my S-T Thudbuster), and Fouriers Trailhead handlebars with two pairs of ESI Extra Chunky grips. Also ordered a pair of SQlab 411 Inner bar ends that will go right next to the inner edge of the outer ESI grips. The S-A 5-speed top bar lever shifter is installed on the left side on the underside of the handlebar. This will leave the top of the whole handlebar for unmolested multiple hand positions for long trail ride comfort.
The “Blacktacular” frame arrived today and looks great! This frame has the Surly Gnot-Boost rear dropouts. It will take 135mm to 148mm Boost wide hubs and 10mm QR, 10-12mm straight axles, or 12mm thruaxles. It also has a Rohloff torque arm slot and trailer hitch mounts, in addition to fender and rack mounts. The front 29+ fork is 100mm wide and accepts 9mm QR or straight axles.
Let the fun begin!
Let the fun begin!
