TSDZ-2 Montague Paratrooper Ground Up Build
    I finally picked the frame up and immediately started mocking up parts. This one will probably see some use commuting to class. But I need to finish it first.
    Brakes are a huge to-do. Seatpost needs a thicker shim or really to just buy something that fits. The fitted seatpost is structural to the Montague frame. Of the few reports of frame failure I read, it seems a shimmed seatpost was a common theme.
      Originally posted by moarpower View Post
      Not an update... I remembered that I asked eyebyesickle to put a 36V winding with a 52V capable controller. The idea was to hopefully increase the maximum pedal cadence before the motor “revs out” at the expense of torque. I had planned to use it on my old road bike for a commuter/hill bomber but have neverhad the heart to take that bike apart.
      I want to do the same. However, i'm having a hard time finding information about different versions and which i should buy.
      Do the 36v, 48v, or 52v version actually have different winding in the motor? I cant find details about this anywhere. Is there an "overdrive" version? Is "overdrive" just field weakening as standard?
      There is a helical gear version and a straight cut, is the old straight version still common? Should i make sure i get the helical gear version?
      https://github.com/OpenSource-EBike-..._wiki/wiki/FAQ
