2019 RSD Mayor V4 BBSHD Build
    New build using RSD Mayor V4 frame. Huge tire clearance with this frame. You can very easily run Snowshoe 2XL’s on a 100mm Wheels. I’m running 80mm wheels because I had them on hand and didn’t feel like springing for new wheels. Only downside to this frame is your not going to run anything other than a single speed setup. The chain stay angles are so aggressive in order to fit the five inch plus tires that anything other than a single speed will give you a really wonky chain line. I’m currently running a 36/13 gearing but will soon be changing to 28/13 for more off-road friendly setup. The plus side is a simple super clean bike with very little wires to hide.
    Great looking bike! Do you have any pictures of the BB area on the right side? What did the chain line end up being?
    3rd build, 2018 Crust Evasion step-thru, BBS02, Shimano Nexus INTER-3 IGH
    Visit the forum knowledge base
