Dual Motor SP180C2
    Dual Motor SP180C2
    Guys. I'm doing experiments on crazy power configs for the surron (not top speed more torque and speed balanced). You may have seen my other threads as i've learned the Surron motor cannot exceed 12kw burst and 8kw continuous power (2mins) if you run a BAC4k with 60v battery. If run 72 volts battery you likely can get the stocker closer to 14kw bursts. But not for long before the magnets break.
    Anyone real life build experience using this motor? Or know someone that does? The same motor manufacturer of the surron stock motor named SP180C1 makes a dual motor named SP180C2. It's specified to burst to 28kw and 16kw continuous for 2mins. Let me know please.
    here you can read about the Surron motors:
    https://evnerds.com/electric-vehicle...cle-companies/
