Hello everyone,
New here!
First of sry for the bad english its not my first language. I've been reading a lot on the BBS programming topic. I'm currently modding two bikes with a BBS02 and a Sturmey Archer 3 speed Hub. Lots of long big hill in my area so i'm going for efficiency and range before speed. I'm planning to limit speed at around 30km/h (19mile/h)
i'm going into all of Luna's app setting before actually plugging in the motor and making some change and i have a couple of question about some setting.
My goal is to have a simple to operate bike (some possibly 1 or max 3 PAS lvl) and the Sturmey archer will be the deciding factor for speed and hill climbing. I'm looking to have a consistent power usage so i know always how much range i have (or close to)
Battery is to be determine (52 volt vs 48)
Here are the settings i don't understand :
Designated Assist Level : ? Does it restrict PAS to only one lvl the one i chose ?
Start Current in relation to Slow-Start ? Seems from the PDF instruction that Slow Start can't be low if Currents is low and in a low gear? Not sure i am reading it right.
I would love to have the motor use less power when on flat vs hill or decent(usually not pedalling on decent) so is the setting :
Keep Current ?? Should i set this to like 20% ? My understanding is that the current will go down to 20% if no more is needed to keep the current speed?
Thanks all for your input !!!
Cheers
New here!
Cheers
