Hey guys, Edit: Both of these bikes are for purely offroad use... I do not take these on the street. The 29er is for more hard packed single track, the fat bike is for sand and snow.
So I have two BBSHDs... one 68mm BB with the old standard display bought from Lunacycle in offroad mode. This is on a 29er front suspension mountain bike. Has a 40 tooth sprocket on it.
The second BBSHD is a 120mm BB on a Salsa Mukluk fat bike. Unfortunately I have to use a much larger 46 tooth sprocket because I need significant sprocket inset to have the chain line reasonably straight mid-cassette. This BBSHD came from an Aliexpress seller. 500c display on this one.
Both run off the same Luna Wolf 52v battery.
The first bike, the 29er, has a very 'punchy' throttle response. When going up a steep hill and hit the throttle, I get a pretty good push. Enough of a push that it easily spins the tire on loose surfaces and easily lifts the front tire on more firm surfaces.
The fat bike, however, is not so punchy. The motor has the power, it is usable in pedal assist mode, and it has the push to get me up to 50km/h, but when I punch the throttle on this one I can feel it, but not much. It certainly doesn't lift the front tire or spin the rear tire (of course I have a lot more traction with a 10psi fat tire than a skinny 29" aired up).
So finally my question... ignoring the gearing issues which I am trying to find better solution for sprockets etc, what setting do I need to change in the programming that would give me more 'punch' in the throttle?
I'll attach my two .el files so you can see the difference. I would just overwrite the new controller with the old controller file, but I like how it responds for everything else (pedal assist, etc), so am leaning towards just changing the throttle portion.
Both of these files are as received from the seller, I did not change anything:
Original BBSHD from Luna Cycle
New controller file from aliexpress
[Basic]
LBP=41
LC=30
ALC0=1
ALC1=20
ALC2=30
ALC3=40
ALC4=50
ALC5=60
ALC6=70
ALC7=80
ALC8=90
ALC9=100
ALBP0=1
ALBP1=85
ALBP2=85
ALBP3=90
ALBP4=95
ALBP5=96
ALBP6=100
ALBP7=100
ALBP8=100
ALBP9=100
WD=10
SMM=0
SMS=1
[Pedal Assist]
PT=2
DA=0
SL=0
SSM=2
WM=0
SC=10
SDN=10
TS=20
CD=8
SD=0
KC=60
[Throttle Handle]
SV=11
EV=35
MODE=1
DA=10
SL=0
SC=10
LBP=41
LC=30
ALC0=1
ALC1=20
ALC2=30
ALC3=40
ALC4=50
ALC5=60
ALC6=70
ALC7=80
ALC8=90
ALC9=100
ALBP0=1
ALBP1=85
ALBP2=85
ALBP3=90
ALBP4=95
ALBP5=96
ALBP6=100
ALBP7=100
ALBP8=100
ALBP9=100
WD=10
SMM=0
SMS=1
[Pedal Assist]
PT=2
DA=0
SL=0
SSM=2
WM=0
SC=10
SDN=10
TS=20
CD=8
SD=0
KC=60
[Throttle Handle]
SV=11
EV=35
MODE=1
DA=10
SL=0
SC=10
[Basic]
LBP=42
LC=28
ALC0=0
ALC1=20
ALC2=20
ALC3=30
ALC4=40
ALC5=50
ALC6=60
ALC7=70
ALC8=80
ALC9=100
ALBP0=0
ALBP1=44
ALBP2=51
ALBP3=58
ALBP4=65
ALBP5=72
ALBP6=79
ALBP7=86
ALBP8=93
ALBP9=100
WD=10
SMM=0
SMS=1
[Pedal Assist]
PT=3
DA=0
SL=0
SSM=3
WM=0
SC=50
SDN=4
TS=25
CD=8
SD=0
KC=60
[Throttle Handle]
SV=11
EV=35
MODE=0
DA=0
SL=26
SC=10
LBP=42
LC=28
ALC0=0
ALC1=20
ALC2=20
ALC3=30
ALC4=40
ALC5=50
ALC6=60
ALC7=70
ALC8=80
ALC9=100
ALBP0=0
ALBP1=44
ALBP2=51
ALBP3=58
ALBP4=65
ALBP5=72
ALBP6=79
ALBP7=86
ALBP8=93
ALBP9=100
WD=10
SMM=0
SMS=1
[Pedal Assist]
PT=3
DA=0
SL=0
SSM=3
WM=0
SC=50
SDN=4
TS=25
CD=8
SD=0
KC=60
[Throttle Handle]
SV=11
EV=35
MODE=0
DA=0
SL=26
SC=10
