Brake Sensor Connector
    I bought ebike brake handles with brake sensors built in that connect to the controller via a black two pin connector. The controller has two identical large white connectors that are labeled "low brake". Can i solder on new connectors to match? Do i need different brake sensors? What are these connectors called? I think the black ones are JST something but I am not sure. The motor is a cyclone 3kW if that makes a difference. Any help is appreciated..
    You can buy connector kits to make whatever end is necessary. I also built up a Cyclone kit, and figured that keeping the controller closer to stock is more important. I was able to find the JST and molex connector kits on Amazon, along with the proper crimper. I just modified the sensor end when necessary. It took me a few tries to get the crimping technique down.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Jose
