Battery info for a converted dh project
    Hi, I already built a sts gt 48v with 1000w engine + my son one with a 48v@500w. I just bought a chili wrap 210 with in head to convert it also. I want a battery for it that is very light (as my current setup) but with the most discharging rate/wattage. I can see there is high capacity batteries with lower discharge rate and vice versa. Are the discharge rate directly related to the capacity (ah)? Can I get a 10ah battery that would be in 48v powerfully enough to feed a 1000w controller/hub ore more?
    Second question related to the first one, if I link in serie a 12v let's say 8ah with a 36v 8ah batteries (I keep separate chargers and a switch button to dissociate it) will it be the same than a 48v 8ah or the wiring internal contrĂ´ler/organs (bms related?) will be different and the 1st configuration weaker than the second?
