List of BIKE BUILD THREADS to be BBSHD or BBS02 Compatible (Pictorial)
Fito Modena GT 2 BBS02 Build.
**Had to use eccentric BB adapters and add a through bolt to secure them.
Not a full "how to" thread but contains a decent amount of info and troubleshooting. As pictured cost was about $1600.
Santa Cruz Super 8 (1999) Build Thread BBSHD Ludicrous. (In progess)
Full build instruction thread yet to come. Got a lot of kinks to iron out first.
Added BBSHD to 2016 Motobecane Fantom 29er. Bike was about $1400, motor kit, suspension post & street tires, about $1200. 68mm Kit installation went smoothly. I think the only item that I needed to replace from the kit was longer bolts for the chainring, plus spacer. Decided to create a relaxed, sit upright ride from the mtn bike due to chronic arm pain. Bike rides comfortably, my back, shoulders and neck also like sitting upright. To do this I swapped out the flat handlebar for a riser on headset & sweepback handlebars. The thudbuster is wonderful with my old, comfy brooks saddle. I used a dolphin bracket as I already had a few of those 52v dolphin batteries working on my other ebike. With the 48 chainring this thing cruises quietly and efficiently at 25 mph +. I'm not so impressed with the glue on brake sensor. I'm finding pausing peddling a couple seconds before shifting works fine for me. Would be nice if there was a dependable, instant motor kill option for shifting. In the future I could make this a mtn beast by swapping out the chainring, street tires and removing the headset riser. After a few long test rides, I'm happy with this bike & the quality of Luna products.
2011 Specialized Epic Fsr Comp frame M with BBS02B 750W and 48v 17ah Shark style battery
Link to build log.
Electra Alloy Cruiser 3 converted to 29+ 5spd IGH with BBS02B 750W/48V in frame triangle mid-drive (fits right in without tube modification).
Build thread here: https://electricbike.com/forum/forum...iser-3-project1 PhotoLast edited by Rider; 01-21-2018, 10:10 AM.MOVING BACK TO PEDAL...
Soma B-Side V.2 Belt Drive 3spd IGH 27.5 x 2.8 with BBS02B 750W/48V mid-drive.
Build thread here: https://electricbike.com/forum/forum...v-custom-build1 PhotoMOVING BACK TO PEDAL...
Minnesota 1.2 with BBSHD 21” frame
Bafang BBSHD Mid Drive Ebike Kit
(Choose Your Programming Level: 750w Street Legal, Bottom Bracket Size: 73-100mm (Fat), Chain Ring: Stock 46T Steel Chain Ring, Bafang Handles with Ebrake Cut Off: Bafang Handles with Built-in Ebrake cut off, Add an Additional Luna Designed Chainring: Luna Aluminum Chain Ring Adapter With 42T Sprocket $40.00, Display Options: Bafang Display C961, Add a Gear Sensor: GearSensor for Derailers and Internal Geared Hubs $45.00, Throttle Choices: Black Luna Right Twist Throttle $12.00, Make it a kit by adding a top grade battery: 48v Dolphin GA 13.5ah $475.95, Add a 5.5mm Smart Charger for your Battery (Not Included): 48v 3amp Lithium Charger $30.00
toughest part art of my build was removing the main crankshaft and understanding how the tools worked. I ordered the 42T sprocket but ended up not using it since it pushed my chain too far outside my frame. Trying to keep the chain in line I stuck with the stock 46T. Cabling was a breeze to me. Connectors are almost impossible to get wrong. Went with a twist throttle since the bike came with thumb shifters. Probably should have went for the full color display. I plan to add fenders and a kickstand. Bike bounces a little when I pedal. It’s a blast just to hold the throttle down...so smooth. I might add front shocks someday to help smooth the ride.
The Raleigh Kodiak 27.5 plus tire full suspension bikes should be compatible with the BBS02 since they have a 73mm bb width. We are currently putting one together now with a 750w tsdz2 mid drive motor and it fits well. Not much room for a battery inside the frame though. The battery is the least of my problems, getting the dog carrier on the back of the full suspension bike is taking a bit of work.
