List of BIKE BUILD THREADS to be BBSHD or BBS02 Compatible (Pictorial)
Our updated ebike conversions. For the wife I converted a 2018 Specialized Roll Step-Through and mine is a 2018 Trek Marlin 5.
I reused the bbs02s off our old 1993 Rock Hoppers Comp and purchased hydraulic sensors for the brakes.
Really like the way they turned out.
For the Roll I was able run an extra long Bafang wiring harness through the frame on the right side where the front derailleur ran. Had to drill out the hole for the cable to fit and also cut the head off (didn't want to drill a big hole, just the size of the cable) and resoldered it back on where the cable exits near the bottom backet. Also had to grind a little out of the middle of the bottom bracket so the bbs02 would slide through and shorten the battery cable for a custom fit.
The Trek was a breeze, only had to slightly dent (panel beat) the chain stay, about 4 mm, so the lekie 42 would clear. I did this instead of shims for fear of messing up the chain alignment. Now I need to tidy up the wires up front and call it done.
We really enjoy the upgraded frames. Hydralic brakes are wonderful.5 Photos
PROJECT 2018 - CANYON Torque EX Enduro BBSHD 52V Backpack Accu
DETAILS
01 - PEDELECFORUM - GERMAN
02 - DEUTER - ATTACK BACKPACK | ACCU
03 - LUPINE - LED-LIGHT - FRONT | REAR
04 - REAR SHOCK - CANE CREEK DOUBLE BARREL AIR | ROCKSHOX VIVID R2C
05 - BAFANG - DOWNLOAD BAFANG BBSHD SETUP - TOUR LOW | MID | HIGH
06 - MUDGUARD - MARSH GUARD | SKS FENDER | MOTOR SKID PLATE
07 - CREATIVE SOUND BLASTER ROAR | BLUETOOTH WIRELESS SPEAKER
08 - BAFANG - HYDRAULIC DISC BRAKE SENSOR | BRAKE SRAM GUIDE R
09 - TYRES - MAXXIS MINION DHF | CONTINTENTAL MOUNTAIN KING
10 - BOTTLE CAGE - TOPEAK MODULA CAGE EX | RED BULL
Modell: CANYON TORQUE EX GAPSTAR 2016
Frame: CANYON TORQUE EX (WITH CUTTING ISCG STUDS)
Color: RAW CLUB
Rear Shock-1: CANE CREEK DOUBLE BARREL AIR (240 mm x 76 mm)
Rear Shock-2: ROCK SHOX VIVID R2C (COIL SPRING 300 lbs / 350 lbs)
Fork: ROCKSHOX LYRIK RC SOLO AIR
Headset: CANE CREEK 40
Rear Derailleur: SRAM GX, 11S
Shifters: SRAM GX, 11S
Brakes: SRAM GUIDE R
Derailleur Hanger: NR. 21
Cassette: SRAM XG-1150, 11S, 10-42
Wheelset: DT SWISS FR 2090 26 INCH
Tyres: MAXXIS MINION DHF EXO 3C / CONTINENTAL MOUNTAIN KING
Motor: BAFANG BBSHD, 68-73 mm + 2 x 2 mm SPACERS
Bafang: DISPLAY DPC-18 WITH ECO/SPORT, GEARSENSOR, BRAKESENSOR, THROTTLE
Chainrings: LEKKIE 42T FOR BAFANG BBSHD + 1 x 2 mm SPACER (PERFECT CHAINLINE)
Chain: SRAM PC-1130 / 120 11S
Stem: RACE FACE RESPOND
Handlebar: RENTHAL FATBAR
Grips: ERGON GS2
Saddle: SQLAB 610 ERGOLUX ACTIVE
Seat Post: ROCKSHOX REVERB STEALTH
Pedals: SHIMANO PD-MX80
Accu: 52V 14A 728WH HAILONG BOTTLE ACCU 36 x 9 x 9 cm
Accu-Cable: ÖLFLEX-CABLE + XT-90S ANTI-SPARK CONNECTOR
Backpack: DEUTER ATTACK
RAM-Mount: RAM-MOUNT FOR NAVIGATION TOURATECH GARMIN GPSMAP60CSX
LED-Light: LUPINE ROTLICHT (REDLIGHT) / BRAKE SENSOR, LUPINE PIKO R7 REMOTE
Wireless Speaker: CREATIVE SOUND BLASTER ROAR BLUETOOTH WIRELESS SPEAKER10 PhotosLast edited by blackraider; 09-24-2018, 04:43 AM.
Scott Sportster P3 2008 e-Powered by Bafang BBSHD
Check out the Build here: http://electricbike.com/forum/forum/...my-first-build
This is my 3rd build using a Specialized Roll. This time I used the Step Through size small. I am happy to say that changes in the bottom bracket required zero grinding to insert the BBSHD. Previous Rolls required substantial grinding to the aluminum between the threads in the bottom bracket. I used a household wire channel from home depot to tidy up the wires on the underside of the frame heading to the handlebars. As you can see I have not finished the wiring to the battery. Any suggestions for discreet cable routing are welcome. The Roswheel bag on the back is 18$ from Amazon It's bigger than what is required for the 52v 17ah panasonic but it can hold the killer whale pack which I used it for in another build....I may build a custom box or bag for this bike. She rides like a dream. Had her on the maiden voyage last night!
1 PhotoLast edited by Churnmaster; 12-12-2018, 10:50 AM.
Up a little is a close one: https://electricbike.com/forum/forum...8820#post78820 - hope the picture tells a thousand words.
Looks like a BBSHD and stock pie plate to a disc Nexus 3 IGH with a chain tensioner.Last edited by ncmired; 04-24-2019, 11:38 AM.
The "Better Ruffian"
BBSHD/ Phaserunner @ 52V/ 50A dual Samsung 25r 12.5ah packs in Parallel
Ruff-Cycles Basman Frame, Tank, Fenders
All other Parts from various sources, most listed and linked
Current Cost(upgrades people) $2900
https://electricbike.com/forum/forum...need-your-helpLast edited by Defjr333; 09-16-2019, 01:37 PM.
- Likes 1
Would Admin kindly move pics to above post. Sorry and thnx2 PhotosLast edited by Defjr333; 09-15-2019, 07:12 PM.
2019 Giant Trance 2 (I love my 1998 K2 build (Luna BBSHD mid-drive) so much I was a little worried about whether I could be happy with a new build.) But I am SUPER happy with this build. This is my second build with the BBSHD mid-Drive kit. Bike cost was $2300 Kit cost was about $1500 The bottom bracket has outer tabs (seeLast edited by prh88; 09-18-2019, 03:10 AM.
- Likes 1
See link for build report
1999 K2 900 Build with BBSHD Mid-Drive 1999 K2 900 Bike cost was $1000 in 1999 Kit cost was about $1400 in 2018 This build was done in 2018 on my like-new 1999 K2 900. It is like-new because it has been hardly used at a second home in Park City. Whenever people see me on it, it is common to hear comments like, “Hey I used
1999 K2900. This is my first build with the BBSHD mid-drive kit. Bike cost was $1000 in 1999. Kit cost was about $14001 Photo
