Here is a brief story of the build of my Rocky mountain bike with BBSHD. I had an ebike from 2011 to 2015. it had only front suspension and it was a rear hub motor. It was nice but i broke rear wheel 2 times because hard impact. I had to take care about bumps and that annoying me. So i decided to sell the bike and go for my new project, ebike 2.0!
I bought early in 2015 a brand new Giant Trance 27.5. I checked everything that could be the perfect bike except the most important thing (now i know!), the bottom bracket. I choose Giant because it's a big name and i said that they should be standard on all aspects for the kit. But i learned, since around 2012, Giant changed the standard BB for a 92mm pressfit. OMG! I realized i cannot build my ebike, Unfortunately i sold it (and loss 800$ CAD). Then my project started from zero. The other thing that i did not expected that could be a little bit problematic is Giant had a curved downtube. that means the clearance of the BBSHD from the ground would be less then a straight downtube.
After a lot of searches i found that Rocky mountain bike before 2012 could be a very good candidate. Mine is a 2006. It have double suspension, hydraulic brakes. Everything was easy to install. Here is a list of what it cost to me until now (prices are in CAD$)
The kit i bought from Luna cycles includes this:
(Bottom Bracket Size: 68-73mm (Standard), Choose Your
ChainRing: FREE UPGRADE: Luna Aluminum Chain Ring Adapter
With 42T
Sprocket, Display Options: Luna Full Color Display $45.00,
Throttle
Choices: Black Luna Right Twist Throttle $12.00, Add a Gear
Sensor: Mid
Drive Gear Sensor for Derailers $49.95, Add of Pair of
Hydraulic Brake
Sensors (Kit comes with ebrake hand grips): Magnetic sensors
to use your
own brake levers $15.00, Optional Programming Cable: Bafang
Programming
Cable $19.95, Make it a kit by adding a top grade battery:
52v Shark
Panasonic GA 13.5ah $545.95, Add a 5.5mm Smart Charger for
your Battery
(not included): 52V Advanced 300W Luna Charger
$79.95)
Here is the beast :-)
Installation was almost easy. Due to the hydraulic brakes, i had to bought the hydraulic brake sensor kit. I had difficulty to adjust the magnets for the perfect brake control. The play to a good adjustment is too small, making hard to adjust very well. Finally the rear brake is adjusted correctly but the front brake sensor is unplugged due to problem of adjustments.
The gear sensor work fine. But for now my rear shock have to be replaced and give big movement on the bike that active the gear sensor and it stop the motor, so the gear sensor is unplugged until i repair the rear shock.
For the motor itself, i added a steel plate that link the motor and the seat stay. I did not bought the tool to tighten the motor on the BB (maybe i should?). I was able to tighten it anyway. But after several trial, i realized the motor begin to move back and forth. To avoid overtighten, i installed the plate and then nothing can move. See next picture.
I placed also a piece of wood between the motor and the downtube, an extra precaution to avoid any movement of the motor and to avoid damage on the downtube. (On my first trials motor moved up to downtube and it did a bump on it...)
Next step i will install the Luna eclipse chainring, but i have to install spacers due to conflict with chainring and the chain stay. I ordered 2 spacers, but maybe i only need one, i don't take chance to wait another 2 weeks of delivery ;-)
Here is some pics of BB of the bike:
I commute with the bike everyday, 50km. One thing i did not expected with this bike, is to be in very good shape, even if i use the pedal assist! My first ebike was only twist throttle and the bike was geared the way i could not help it. With this bike, i'm always pedaling and my challenge is to use the less of wattage as possible, so day after day, i do exercice and i like it. I fueled my car on july 8th, and the next fuel was on august 18th, all this because i commute with the bike mostly everyday.
Now the summer vacation is ending and the traffic will grow up in the next weeks. Maybe in 2 weeks it will take less time to go to work with my ebike than going with my car. Same thing for evening return. You can't imagine how fun i have to pedaling at 50km/h while there is kilometers of cars waiting the green light to move... priceless.
Hoping my report help you in your project and don't hesitate to email me if you have any question.
Last thing, my top speed with a good wind in my back and the stock bafanf 42T chainring is 68.6km/h :-) (42.6m/h)
| 2006 Rocky Mountain Element 50 (used) | 950.00 $ |
| kit ebike Luna cycles BBSHD | 2 081.84 $ |
| customs | 173.60 $ |
| bracket rear derailleur | 45.98 $ |
| derailleur cable, alignment | 21.55 $ |
| chain, tube | 70.91 $ |
| selling ebike 1.0 | - 500.00 $ |
| mud guard | 27.58 $ |
| 2 continental tires | 94.25 $ |
| adjustement | 25.00 $ |
| change derailleur cable, position gear sensor, changed 1 spoke | 42.52 $ |
| Luna cycle eclipse chain ring aluminum | 155.14 $ |
| Luna cycle eclipse chain ring spacer (2) | 26.83 $ |
| Grand Total (CAD$) | 3 215.20 $ |
With 42T
Throttle
Sensor: Mid
Hydraulic Brake
to use your
Programming
52v Shark
your Battery
$79.95)
