Giant Fathom 2 2017 Bafang EBIKE Commuter Build
    Project:
    Build ebike with existing MTB. Giant Fathom 2 2017. Maintain a circular economy.
    Mission:
    Ride 30km to work and home again 5 Days per week
    Reason:
    Play my part in reducing car use. Get back into shape lose some weight and get the happy hormones flowing again.
    BOTTOM BRACKET:
    FSA, Press fit
    So Im going to write up my build here. Jon E B Good.
    Click image for larger version  Name:	20170804_085021.jpg Views:	0 Size:	1.44 MB ID:	155701
    Click image for larger version  Name:	20220910_081058.jpg Views:	0 Size:	986.6 KB ID:	155702
    Click image for larger version  Name:	20220910_081037.jpg Views:	0 Size:	685.4 KB ID:	155703
    The Giant Fathom 2 2017 Spec
    So got my bike specification from 99 spokes on this link https://99spokes.com/en-EU/bikes/giant/2017/fathom-2
    Click image for larger version  Name:	Giant Fathom 2 2017 Spec.jpg Views:	0 Size:	66.7 KB ID:	155708
    So my Bottom Bracket FSA Press fit
    So my next job is to find an FSA to BSA adaptor that is 90mm wide or to decsribe it better 90mm long to fit my 90mm long bottom bracket.
      So it turns out GIANT works closely with Shimano and tends to use Shimano BB86 and BB92 bearings a lot.
      Click image for larger version  Name:	BB86 and BB92.jpg Views:	0 Size:	32.8 KB ID:	155710
      So my bottom bracket falls into the BB92 Size. When I measured my Giant Fathom 2 2017 bottom bracket I measures a with of 90mm and a diameter outside the shell of 45 mm with FSA Comet cranks.
Name:	BB86 AND BB92 Technical info.jpg
      Thanks to https://wheelsmfg.com/bb86-92-tech for the time and effort to share this info.
        So now the task is to go from FSA / BB96 to BSA
        wondering if is this the way to go PF-41 adapter for Press fit bottom brackets https://lunacycle.com/pf-41-adapter-...ttom-brackets/
        With the BBSHD
        Click image for larger version  Name:	BBSHD 48V1000W 100MM.jpg Views:	0 Size:	77.1 KB ID:	155717
        ‚Äč
          Wow... Keep up the good work!
