Continental Prime 48v
    Hello guys, new guy here.
    I have a Continental Prime 48v mid-drive ebike with a dead controller. I want to install a KT s06s in the motor housing completly replacing the old controller, display and pas sensor. My only concern is the hall sensors. There are only 4 wires which i identified one to be GND and the remaining 3 to be signal. I tried the pull-up 10k to 5v but i got no signal. Should i try lower 4.7k? I dont want to install a cheap square wave controller that do work with-out hall. What would you suggest?
    Hi, I have same motor. I just replaced the gear wheel with a 3D printed one and now I get error E23 and after clearing sometimes E10. E23 is temperature sensor related. Did you figure out where is the sensor? I want to bypass it.
