Build List (prices include tax & shipping)
Link to lots of build pics: https://goo.gl/photos/dN4vUje9GAnYkkD7A
Most challenging aspects of the build:
Aside from getting into an internally geared set-up, any suggestions on keeping the rear derailleur in one piece?
- Donor Bike: 2014 Giant Trance 3 27.5 Large Frame; 2x10 gearing (craigslist) $800
- BBSHD 100mm Kit $700
- Gearsensor $50
- Sharkpack 52V GA $550
- Luna Eclipse $100
- FSA BB30 to Threaded BB Conversion Adapter $20
- Press fitting the adapter was challenging since I used a DIY headset press and lining up the adapter bushings perfectly wast tough. Also needed to use the hacksaw to cut the part in two.
- Hacksaw Moments
- Needed to hacksaw frame tabs under the bottom bracket in order to fit the BBSHD. Note that the BBSHD is mounted very low and does not rotate up against the bottom tube because the frame tabs keep it from rotating.
- Hacksawed the bottom bracket adapter to get the Luna Eclipse as close as possible to the frame to decrease the exaggerated chain line
- Hacksawed various cable tabs that got in the way of the battery cradle
- Fitting the Battery
- Pre-build, I thought the triangle would fit a sharkpack in its normal orientation. It doesn't. I had to invert the battery and only use one allen bolt in the water bottle cage holes. Needed to allow the cradle to rotate so that I could remove the battery - the fit is ridiculously tight. To secure the cradle and battery from rotating, I use the two rubber feet that come with the cradle and use a velcro strap. The battery is very secure. Now I have the option of simply charging while the battery is on the bike or removing the battery by rotating the cradle.
