I do a lot recreational cycling on dedicated bicycle paths on my little Brompton folding bike, not exactly the idea bike for this type of riding. However, on my return home, I must ride up some pretty steep hills which are taxing on my bad knee.. I came across an e-bike shop with a variety of e-bikes ready to go. I liked the comfortable upright ergo's of the Pedego Interceptor. A test ride revealed the thrill of riding an electric assist bike, I was hooked, but with the 15Ah battery, the cost in Canada is $4300CAD plus 13% sales tax: $4859CAD (US$3700). The same bike sells in the US for US$3300 (with the larger battery) and sales tax varies by location, unless you buy it online. I just couldn't wrap my head around paying that much for a bicycle, which is basically a $600 or $700 bike at most and another $3000 for the hub drive, battery, controller, cadence sensor, display, etc..
I started researching what other options are available. I settled on the Luna Cycle mid drive unit kit which costs $669 plus you get to choose the battery that suits your needs and your budget. I then settled on an Electra Townie as the bike which I will buy to convert to mid drive e-assist. The Electra Townie has a very roomy front triangle which can accommodate various sizes of battery packs. The bottom bracket is far from the rear triangle with is "flat foot technology" position, which also allows me to install the mid drive without any modifications or head scratching. I bought the bike in black so the wires and zip ties don't stand out too much.
I rode my 7 speed Townie for a couple of months and really enjoyed it. It's comfortable and the gearing is prefect for my type of riding. I wanted to install mini ape handlebars to raise the bars and bring them closer to me so I'm seated in a more upright position but they were on backorder for several months to come, so instead, I tried beach cruiser type bars and really liked them. Plus, these handlebars have a lot of real estate which will allow me to mount the e-bike display, and its controller, throttle, mirror, bell, cell phone mount.. I paid $540CAD (US$411) for the bicycle.
My mechanical skills: I'm pretty handy but wouldn't say I'm an expert bicycle mechanic. The level of skill on a scale of 1 (easiest) to 10 (hardest) to install the Luna Cycle BBSHD mid drive unit would be a level 2.
So it begins:
I don't have the tools needed to remove the stock crank arms and bottom bracket. I priced them and it came to about $40, so I took the bike to my local bicycle shop and they charged me $15. I figured how many times am I going to use those tools anyway..
The Luna BBSHD included:$669
(Bottom Bracket Size: 68-73mm (Standard),
Chain Ring: Stock 46T Steel Chain Ring,
Luna Designed 42T Chainring: Luna Aluminum Chain Ring Adapter With 42T Sprocket $40.00,
Display Options: Luna Full Color Display $45.00,
Bafang BBSxx Universal Thumb Throttle,
Bafang Handles with Built-in Ebrake cut off,
Luna Wrench $19.00,
Dolphin 52v GA 14ah $545.95,
Smart Charger for your Battery (not included): 52v Advanced 300w Luna Charger $79.95)
XT90-S Connector set with Pigtails $5.95
I also purchased 3 throttle, brake Bafang 40" extension cables for $20 each in case I needed them.
I hummed and hawed about my battery choice. I was tempted to get the biggest battery which is the Killer Whale but at 5" wide, it would have been a bit too wide to fit on the downtube with the pedal coming very lose to hitting it. I could have mounted it on the rear rack, but in the end I decided to go with the Dolphin 52v GA, 14ah.
I watched the video instructions on the Luna site which are posted on the BBSHD page.
I mounted the battery mount. What I should have done was to solder on the battery mount terminals, but I figured I could do that later because like a little kid, I was eager to get this kit installed.
I slipped the BBSHD into the bottom bracket opening. Then rotated the motor up towards the frame and secured it with the included hardware, as per the video instructions.
I used the Luna bottom bracket wrench to tighten both fastening rings. I didn't need to add any of the spacers included.
I slapped the chain back on, without any problems. Then I put the pedals on and spun the rear wheel and had my son change gears up and down to be sure the chain moves well and doesn't fall off. No problems.
Now I moved on to the handlebars. I remove the stock brake levers, I removed the brake cables and installed them in the e-brake cut off brake levers:
Then I mounted the LCD display and its controller (on/off, plus, minus buttons), and I mounted the thumb throttle on the left side, because my rotary shifter is on the right side.
And obviously, this kit was designed for e-bike dummies like me: all the component electrical connectors are color coded: yellow to yellow, green to green, etc.. plug and play.
Here's what it looks like finished and on the road:
I then installed the rear wheel speed sensor. There's a magnetic sensor which attaches to a wheel spoke and the pick up which attaches to the rear frame.
Now I was ready to solder the XT90-S Connector set with Pigtails to the battery mount terminals and also to the Bafang mid drive unit. I cut off the connectors that it comes with and soldered these terminals on. I would say this was the hardest part of the whole job because I had to have my son hold the wires steady while I soldered, then slipped the heat shrink tubing over the solder.
I then used UV resistant black zip ties and tied everything up.
I couldn't wait to go for a ride, so I put on my slippers, opened the garage door and off I went like a 6 year old!! Yeeehaw!!
I used a rubber strap to add some more secure reinforcement to the battery mount, as I'm not overly confident with the 2 water bottle bosses.
So it begins:
Luna Wrench $19.00,
