BBSHD on Specialized Fuse Comp, size M
    I rode a buddies electric bike late last year and since then contemplated buying or building one myself. I did quite a bit of reading on electric bikes since then and about a month ago decide to get one for commuting as I finally got fed up with traffic, it takes me 12 min to go 10 miles in the morning but 30-40 to get home. I been following Karmic bikes and was highly interested in the Koben S but as I can take the street or trails part of the way I wanted something that I could ride on the street or dirt. So I started looking at 29er's with hydraulic brakes but I just happened to find this article https://www.empoweredcycles.com/blog...d-drive-motors and thought that would be perfect bike. Instead of a 29, it's a 27.5 with a 3" wide tire and it's awesome. Sorry for not having pics documenting from start but was just to eager to get started. Here's the final product.
    Purchased from luna
    Bafang BBSHD 1000W Mid Drive Kit *
    BBSHD - 68mm
    BBSHD Stock 46T Chain Ring
    Luna Full Color Display DPC-14 For the BBS02 and BBBSHD
    Bafang BBSxx Universal Thumb Throttle
    Bafang Hydraulic and Disc Brake Sensors E-Brake (Pair)
    Bafang BBS02 and BBSHD Programming Cable
    Mid Drive Gear Sensor for Derailers (Still to be installed)
    LUNA Wrench BBSHD and BBS02 Mid Drive Installation Tool
    52v Panasonic 14ah GA Shark Pack
    Standard 3amp 52v Dolphin / Shark / Bottle Battery Charger
    Lekkie BBSHD Bling Ring Chainring 42 tooth - Black
    X90 connectors, still to be installed
    Purchased from other sources
    FSA BB30 adapter (needed press fit, not std)
    FSA PF BB30 adapter
    Chain breaker
    KMC X10 Chain
    Had the crank arms and bottom bracket removed at a bike shop and a pressfit FSA BB30 adapter. Make sure you get the pressfit one, I didn't pay enough attention to the linked article above and purchased the non pressfit adapter, had to re-order and wait a few days for the correct one. Once installed I put in the motor. To get the correct clearance I had to shim the motor with a thin and thick spacer included with the luna kit (there kits come with many needed parts to adapt to different bb sizes) Took a few times to get the correct sizing. With the lock ring I had to use a thick and two thin spacers.
    The luna tool makes installing the next two lock rings a breeze, it I was building these everyday I'd get the torque wrench adapters but no need here. Installed the battery mount, this frame has the 3 holes, and fit is perfect.
    Used black silicone to mount the hydraulic brake sensors (still need to clean it up with a razor blade). Wasn't took happy with the circle magnet rings, dropped both on the floor and they both broke. However I only mounted one using epoxy. On the other I drilled into the brake handle and epoxied in a neodymium magnet that I had. I'll remove the disk later and do the same to the other lever. Much happier with how it mounts in.
    Disk Click image for larger version
    Neodymium Cylinder Magnet
    Installed the thumb throttle on the right side, left side the assist/power, and installed the display. Used a quite a bit of zip ties to clean things up.
    Next is removing quite a bit of wire from the motor and battery and splicing in x90 connectors.
    Quite a bit of excess wiring coming up the seat tube
    did buy a bunch of lights to wire into the main power harness, but after completing the wiring for the two front lights and adapters to the main harness I was unhappy with the amount of wiring on the bike. No longer did it look clean. I then decided since wireless rechargeable lights are so good and affordable I'd just go that way.
    I have to say after a week of riding this bike it's fantastic. It's comfortable using on both street and trail. I can go 20 miles roundtrip on 80% charge to work, mainly uphill on the way there and down on the way back, without worries and not having to recharge. This setup tops out at 33 on the flats with the throttle. Mainly using assist at 6-7 and going at 26-28. Wish the dpc14 was calibrated for 52 watts
    Still need to take care off
    Remove excess battery and harness wiring. Add x90 connectors
    Install gear shift sensor
    Pannier Bags
    I just bought a Fuse Comp 6 Fattie with this exact build in mind. How has it been performing? Any updated suggestions?
    Thanks!
      Apologize, haven't logged in for a while. I'm still using the exact same setup to this day. I'm quite happy how it turned out.
        Hi! Nice build! I'm just finishing up the same build myself. I couldn't fit the second lockring because of lack of space, but it seems to hang on there pretty well.
        Just wondering what kind of bag rack you have on the bike? It looks really practical.
        Best regards
        Magnus
          I have this bike but can't seem to fit the motor 'axle' through the PF bottom bracket, I removed the stock BB and got PF30 from FSA but I can't seem to figure out how to do it, do you have any advice or product links so I can get the right product? Lightspeed
