BBSHD - Motobecane Night Train Bullet
    Motobecane Night Train Bullet - BBSHD
    This bike has the same frame as the Motobecane Sturgis Bullet; thus reference the post by JPLabs for his build details that I followed.
    Donor Bike:
    Frame 17.5" Medium w/11 speed rear cassette ( I added the Thudbuster LT seat post)
    Build purchases
    120 mm BBSHD kit
    Luna Mighty-Mini 30t chain ring
    Display - DPC-14
    Mid Drive Gear Sensor for derailers
    Programming Cable
    Universal Thumb Throttle
    Luna wrench for drive installation
    52v Panasonic 13.5ah GA Shark Pack
    Luna 52v advanced 300w charger
    Universal Hall Sensor Brake Switch 8fun Bafang BBSHD (for rear brake)
    Race Face Cinch BSA BB Cup Tool
    Origin8 2.5mm outboard BB spacer for SHI/GXP (Bag of 10) Note: Luna sends a spacer kit, but there is not enough spacers for this build)
    Jagwire Alloy Stick-On Guides C-Clips (for rerouting rear shift cable)
    Build Summary:
    The bottom bracket removal process was smooth with no difficulties encountered.
    Motor spacing
    Used one 2.5 mm spacer on the chain side to get the motor as close to the chain stay without touching.
    I needed to trim front derailer mount bosses, 8 mm from the forward and 1 mm off of the rear boss.
    Non-chain side I used seven 2.5 mm spacers. I used two washers on the motor mount bracket (about 2.5 mm)
    Rear Cassette Alignment:
    With the 30t Mighty Mini chain ring (since I will be mostly using the bike for single track) I wanted the gearing the 30t sprocket provides)
    When aligned with the front chain ring aligned with 8th gear in the rear.
    When in 1st gear, there is a substantial angle. ​​​​I have about 150 miles on the bike mostly on single track and have not had any problems. I am figuring over time I will be changing out chains and sprocket more often, but I feel it is worth it to have the 11 speeds.
    Rear cassette shifter cable run and Gear Sensor:
    The original bike routes the rear cassette shifter cable through the frame and below the bottom bracket. Due to the way the motor mounts and the placement of the Gear Sensor I decided to reroute the cable via the top tube and then along the seat stay.
    I mounted the Gear Sensor just below the rear of the top tube.
    Speed Sensor
    I used cable ties to mount the speed sensor, had to mount it in a way to avoid wide tire. No additional spacing was required.
    eBrake Switch
    The installation of the eBrake switch was the most challenging and I am not completely happy with the results. Installed on the top side of the handle for the rear brake only, using a cable tie for the sensor and tape to hold the magnet in place. Did not want to use glue for mounting, will continue to seek a better mount.
    Finished bike:
    I have about 150 miles, mostly single track using PAS. It has been an adventure dialing in PAS settings for my mountain biking style.
    Nice build thread, I have added your bike to the list of compatible bikes. Thanks for posting
      That's a great looking build! Nice routing improvement, too. Sweet bike.
        JPLabs and eBikeQuest Without doing research i ordered 100mm bbhsd from you know far country and limited my options. Now facing hard time getting the right bike.
        After extensive research, following are the bikes i can convert
        1. Motobecane boris X5
        2. Framed Minnesota
        3. Framed Wolftrax
        But i see sometimes everyone recommends thru axle wheels for bbhsd. I see both sturgis bullet and night train bullet using same frame and 100mm can fit with offset crank. I see this post in JPLabs build thread. Is it true and can i go with it ? or should stick with boris X5.
        Appreciate your help.
          Good write up, I am inspired to do some write ups. I have a frame for your 100mm HD and I am in Tahoe. The much laughed at Mongoose has 120mm bottom bracket but I fix the chain line problem by cutting it down to 100mm. You are welcome to this frame for free if you do a write up.
Name:	JYzdQEz9xe81iK35BQYTsFCCksX3QVhrNoaPbV9qiliuikauQedmqqZIrMHJCHPjKTuudFzsjQToC7ultXvHU8dwh8xAtBl0BMOqczWdBEjhC_Tj8ezkfQD4DwEJqBh6nTB0Kv66tUs=w2400.jpg
Name:	cSGoSpxZFoshXIA__YrRN2Iid0900xDFUmoCCn2ZyeS7hcajs9kPNo7m9aXAIabhro-1jLN0MeKtok_kuaQ-R-jHFGZ8Q-by2Uvzbd_JAJSb7CUL2dddVEk_LY1xT7pdBlUtgqqtb5g=w2400.jpg
          It is the red one. Long story,
            Great, my post was not approved, whatever that means. Maybe the pictures. You can have a frame of mine for free was all I said.
            If I had your 100mm HD I would do a 24" fat bike. Check this one: https://www.amazon.com/Mongoose-Feat.../dp/B01MTCPYOT
              And why would that be ? Sorry missing the point. You frame got damaged ?
              I'm thinking of Framed Wolftrax or Boris X5. I read in reddit that someone did X5 years ago without any modifications. Not sure frame is same till date.
              • xcnick
                xcnick commented
                Bone yard stories are good. We were riding the black one when the fork failed. (steel is not always real) The fork was borrowed from the red one just to get out of the woods. Now we don't trust Walgoose forks and this frame sat and sat. I may have even more of a bike but it would have blue wheels on a red frame etc. Frame is new but scratched from being stored here and there.
              could you please measure the inside dimensions of your frame. I was planning a similar build, but I don't think my Direwolf battery is going to work.
