I was able to pick the kit up at their Gardena location, and I plan to add the same system to my wife’s Electra Townie & my daughter’s beach cruiser. We can now easily ride the bike path from Redondo Beach to Malibu in hours, and my mountain biking range will increase significantly. Being my first, this build took the better part of a day, including a trip to the bike shop. The next build (on the Townie) should only take about three hours.
I attached the battery using two existing rivnut locations, and adding a self-tapping screw toward the top of the downtube for a total of three attachment points. I drilled a hole in the metal housing of the battery base for the existing bottom rivnut. On this XL frame, there is just enough room for the shark pack. I hard wired the battery base to the motor using butt connectors, which avoided all the extra wire.
