Second Build: Motobecane Boris X7 with BBSHD
    I've got the wide boris (197mm) and like the frame a lot but went with the 100mm which just barely fit and if I were to do it over would go with the 120mm. The pedals are a bit off-center with the 100mm but that was easily remedied with a pedal extender on one side and the chain line is excellent.
    • pure_mahem
      pure_mahem commented
      I think it was one of your posts that made me decide to go with the 120. Cheers!
    #17
    If it had been even 1mm shorter the only way it would have worked would have been to remove metal from the frame and I wouldn't want to risk that
    I helped with another build on a 170mm boris frame and the builder got the 120mm. On that frame the 100mm would have likely fit and we ended up with a large spacer like xcnick did but fortunately didn't have issue he had needing a torque arm and it worked out with well centered pedals and usable chainline - the chainline wouldn't have been any different with the 100mm...
    I tend to agree that the narrowest one that will work is best but it's so close on this frame, even after success with the 100mm if I were to do it over would go with the 120mm
    YMMV
