Finally after about 1000 trouble free miles, I feel I'm ready to do a write up.
In Summer of 2016 - I spend a lot of time researching a cargo bike setup to commute to work and to take my kids to school.
After selling an old car that we didn't need anymore, I finally had the funds and settled on a Bullitt Cargo bike.
This was going to be a complete custom build up.
The Bullitt frame kit with the custom matte black finish was ordered from Blue Heron Bikes, Berkeley CA. (The only Bullitt dealer near San Francisco.)
I sourced the Rohloff (CC DB OEM2 36H) directly from a Rohloff dealer in Germany. It arrived within 5 days via DHL.
Cycle Monkey build up my Rohloff 26" wheel using Ryde Andra 35 rim, Sapim strong spokes. This was the strongest possible build up Cycle Monkey suggested.
Cycle Monkey helped with the belt length calculation and a 108 tooth belt was used.
BBSHD from Luna with a 52v 24ah triangle battery.
Shimano STePS FC-E6000 Crank Arm Set with FSA self extracting crank bolts. (I believe they were 22mm in size.
I really wanted a belt setup and took a chance with getting the Gates parts and ordering the Bullitt frame with the split drop out. I wasn't sure if the Rohloff was going to align with the BBSHD as I knew there was not a lot of wiggle room.
Adding the BBSHD was done once I got the bike home. Luckily I got everything into place with minor adjustments. Gates Carbon Drive belt only allows for 1mm +/- variance on the belt line. I believe the Rohloff requires a 54mm chain line in a 135mm drop out.
The details:
-I did have to grind away a little bit of the BBSHD non-drive side mounting tab to clear the Bullitt bottom bracket.
-The Rohloff uses the 12 spline sprocket carrier(Part 8224). The Rohloff 20T gates cog has a 3mm offset. It is reversible so are Gates front chain rings (50T) . I have the rear cog offset to the drive side and front 50T chain / belt ring offset to the non-drive side.
-I'm using the Luna BBSHD 130bcd Spider Chain ring Adapter, it offered the most offset without going to the Eclipse. (I tried a few different ones - Eclipse has too much offset for the Rohloff
The California ebike Bafang BBSHD Chain ring Adapter HD130 was beefier, but it didn't have enough offset I needed.)
-I had to use 1.5mm washers / spacers between the front chain ring and the chaining adapter to put the front ring further non-drive side.
-Clean the area where the BBSHD interface with the BB real good. My BBSHD had a lot of paint build up in that area and would have added more offset. YMMV (I know, I'm a little bit OCD)
-Get chain ring bolts that has a very thin lip or they will touch the BBSHD body. I used some FSA aluminum chain ring bolts and I have less than 1mm clearance.
-There was no chain tensioner on the Bullitt drop out and the belt was starting to skip under heavy load. I ordered some cheap single speed chain tensioner off amazon and now I can actually register some belt tension using the Rohloff belt tension cricket tool. (Belt skipping problem solved.)
-The bike is setup to be PAS only and my setup when fully loaded is about 330 lbs. (Bike with battery + motor + me and two 6 years old kids) I'm not sure about the range as I have never run out of power. I have only charge to 80% (about 54.5 volts) After 22 miles with the fully loaded bike, I'm at 47 volts. (I do a fair bit of peddling.)
-I think the gearing 50T/20T with the Rohloff is perfect for my commute through the hills of San Francisco.
-Magura MT5 brakes front and rear 203F / 180R.
Me and the kids are loving it so far! If only they will grow up a little slower!
The details:
