Welcome to my post! I"m pretty new at building eBikes or bikes in general so I pretty much pick out the stuff that I think looks really cool and has good reviews. Deviating from the trend I have of using safe and tested hardware with excellent reviews, I found this "Customized Mustang Our Exclusive Fat eBike Frame Fast Dispatching Electric Bicycle Frame With Suspension" on Amazon for $499. The company Risun Motors also sells full bikes with a BBSHD already installed however, I thought it would be fun to build this bike out with nice parts from scratch. With the help of my local bike repair shop I hope to have a really kick ass eBike with dual suspension and 3 inch wide tires.
Frame: https://www.amazon.com/gp/product/B01MUCUJX6
When I found this frame I searched for all the info I could find on it. I really found nothing interesting other than pictures of finished bikes with a BBSHD installed and fat tires. I decided to post this topic for 2 reasons. To document what i'm building for the next time I try to build an eBike, and keep track of what worked and didn't work. Hopefully this could help someone who is interested in this type of frame. This is the only frame I've seen that is full suspension with a place to install a seat tube battery other than folding bikes. Risun Motors also has a seat tube battery that is 48v 26.1ah. I really wish I could find somewhere like Luna that is here in the States that sells a seat tube battery. Possible with better cells to build the battery? Pretty sure with 117 pieces it could go higher than 48v 26.1ah using better ones.
http://risunmotor.com/2015-latest-48...r-and-bms.html
13-Series and 9-Parallels is huge!
Here is a picture of the frame
Here is the finished bike I mentioned earlier with the BBSHD installed my build will probably be about the same price with better components:
https://www.aliexpress.com/item/Risu...04.4.23.FvqFgq
Wheelset: https://www.thegravitycartel.com/col...nt=23550296710
Spank Oozy 395+ Boost Front wheel
Stan's No Tubes Hugo 52 rear wheel with Hope Fatsno 190mm rear hub
3 inch 27.5 tires: Maxxis Highroller II 27.5+ 3.0 Tire 120Tpi / 3C Exo TR
So pretty!
Slight problem here the rear hub is not big enough for the 190mm dropouts and spacers would mess up the chain line.I'll have my local bike store rebuild the wheel with a Hope fatsno 190mm rear hub. Decided against the tire rebuild. Getting a Stan's No Tubes Hugo 52 rim to use with the 190mm Hub. The hub is so wide I think the back rim should be wider.
Hope 4 Fatsno Rear Hub 190mm QR:
http://www.jensonusa.com/Rear-Hubs/H...atsno-Rear-Hub (190mm QR 10/11 speed)
(So lame that the hub doesn't come with a skewer)
Hope Fatsno 190mm QR skewer:
http://www.jensonusa.com/!ZdpcpcOxV9...tsno-QR-Skewer
ROCKSHOX YARI RC FORK 29" / 27.5"+ 160MM: (if you go with this fork and want 3 inch width tires make sure to get the 29/27.5+ version and not the 27.5+ version)
https://www.probikesupply.com/produc...iffusion-black
I'll let my local bike shop figure out what crown and zero stack to get.
Brakes, derailleurs, and stuff
Shimano Xt M780 10 Speed Shifter Black
Shimano Xt Rd-M786 10Spd Rear Derailleur Black, Medium Cage
Shimano HG50 10 Speed Mountain Bike Cassette
Shimano XT SM-RT86 Rotor - 6-Bolt
Shimano Deore M615 Hydraulic Brake Set with Bafang Ebrake cut off (these are awesome!) https://lunacycle.com/shimano-deore-...brake-cut-off/
This stuff is all a matter of what floats your boat:
SPANK SPOON Pedals
SPANK SUBROSA Grips
SPANK SPIKE 800 Vibrocore Bar
Spank Oozy Trail Stem Black, 75Mm
Thomson Masterpiece Bicycle Seat Post
After I (with the help of my local bike shop) get all the parts I have so far assembled, and get another pay check to blow on a BBSHD kit from Luna. I will post pictures of the bike fully assembled and add a list of all the neat stuff I get from Luna.
So pretty!
SPANK SPOON Pedals
SPANK SUBROSA Grips
