I've been doing a lot of research for a winter e-bike build and thought I'd lay out my thoughts here to share my reasoning for others who are considering a build and to get some feedback from others more experienced. I've certainly benefitted from what others have posted and it's time to share. I primarily use my bike to commute to work, 5 miles each way, but also use it to run errands and get around the suburbs and into the city.
I purchased a Marin Muirwoods to use as a donor bike. It's a 4130 CrMo steel self-described "rough and tumble commute machine" with Tektro Auriga hydraulic disc brakes and a 9-speed Shimano Alivio rear derailleur. Weighs about 28 pounds. Got lucky and saw it brand new on deep discount (LT $500 tax included) at a LBS a few weeks ago. The 68mm bottom bracket is ideal.
I'm planning to add a BBS02 mid-drive over the winter. Luna is my winner for the kit. Here's my order from Luna that I placed a few days ago:
Here are some thoughts I went through in researching and thinking this out.
Hub vs Mid
I started out like many thinking a simple 250w hub kit was all I wanted. Just travel my 5 mile commute to work and be a little less sweaty. I was interested in the 250w hub motor partly because it's such a stealth approach but also because I felt I could fairly easily add it and remove it from my bike: one bike to rule them all! Another dream was to be able to install it on other bikes to share the electric experience with others on group rides while I pedal along with them w/ no assist. I was thinking about a super-simple kit that had the hub motor, battery, and on-off switch on the handlebar. At 150 pounds, I'm light and I'm willing to pedal along so I still feel this would have been reasonable. But as I read more and more (and started travelling greater distances on my bike) I came to the conclusion I wanted more speed and power. I researched the hotrodding path but came to the conclusion I'd fry a 250w hub motor. Then I started looking at more powerful hub motors but they were bigger and more obvious. And heavy. I had frequently come across the bbs02 in my research but blew it off for months because "I didn't want a mid-drive". Then one day something just clicked and I started giving the bbs02 more consideration. It's fairly stealthy with its mounting point below the bottom bracket. Check. The controller is integrated so I don't have to carry another brick. Check. I can tweak the programming. Check. It mounts about as low as you could mount a motor which is great for weight distribution. Check. I had to give up the dream of easily moving it from bike to bike. Okay, don't like but let's keep talking. In exchange I get to use the rear derailleur as a transmission. Bonus! 25+mph. Bonus! Hmmmm….yes, this is for me. Mid drive it is.
Prebuilt vs DIY
A lot of really cool prebuilt ebikes exist. It would have been an easy choice that would have gotten me into an e-bike much faster and with LBS support. I went to a LBS and tried a Trek. It was fun but it just didn't feel right to cut out at 20mph, I can pedal that fast and I knew I wanted the ability to go faster. I just didn’t feel it was worth the sticker price. A different Trek that does 28mph is close to $3,000. With DIY, I like the idea of being able to tweak the programming. I live in the suburbs and when I commute to work I'm frequently the only bike I see -- I'm not going to bother anyone going 25mph on the side of a 55mph highway. Plus I'm making a small hobby out of this DIY project, I like the lower cost, and have enjoyed learning more about wrenching, motors, controllers, and batteries.
Steel vs Aluminum
Steel won for me. I just didn’t feel comfortable with aluminum knowing the BBS02 bites into the bottom bracket to help it stay put. I also like the softer feel of the ride and it's such a reliable and dependable material. It appears many people have had successful builds on aluminum and Luna is using them on their own builds which I'm sure they stand behind but the aluminum bikes I was looking at were 25 pounds themselves, upwards of 30 with a front suspension and with the Muirwoods donor bike coming in at 28 pounds, just three more than the comparable aluminum models, I felt more comfortable with steel.
Other bikes I considered:
The Muirwoods was also an interesting combination of lower-end Altus front derailleur (which I didn't care about because it'll be removed) and the next level up rear derailleur from the Alivio line. At least I didn't pay a premium for a front transmission I won't be using.
Disc vs Rim Brakes
I bike in all types of weather and with the increased speed I wanted disc brakes for consistent performance regardless of conditions. I wound up with hydraulic but feel like I could have been just as happy with cables, and maybe even happier, because mounting e-brake cutoff sensors appears to be a challenge because of the way the hydraulic levers work. I'm sure I'll have to tinker with this a bit.
Suspension or No
I went without. I currently commute on a Masi CX cyclocross bike with 700x28c tires. It's a steel frame with no suspension. I travel up to 30mph on the big downhill portion of my commute with no issues or complaints. I have no problem lifting off the seat to avoid bumps and potholes. The Marin donor bike has 700x40c tires which should provide additional cushion from where I'm at now with 28c. For me the front shock just seemed like extra complexity and weight I didn’t need. I'm not planning to ride singletrack or do any substantial off-roading. In short, I plan to ride this like a bike, not sit on it like a motorcycle, so I feel comfortable I'll be fine w/o a suspension.
Gear Ratio/Inches and Wheel Size
I wanted a wide range back cassette to be able to control the load on the motor to prevent overheating on hills and to be able to go fast on the flats. I wound up with a 12-36 cassette in the rear. Perfect. The existing front chainring is 48/36/26. Since I've already got a 48t in the front I got the 48t Bafang chainring and I think this will work great with the 12-36 in the rear. The front-back 48-12 gearing paired with 700x40c wheels should provide a very reasonable cadence of 77rpm at 25mph. Calculate your cadence at speed.
Flat or drop bars
Went with flat mainly for safety. I can be upright riding in traffic with good vision and I can keep my hands right on the brakes where I've got options for emergency stopping/skidding. I might add bar ends for some additional riding positions when not in traffic and for use when out of the saddle.
Battery
I ditched the hub motor but I'm still wanting to make this build as stealthy as possible. I'd prefer not to have a shark pack or bottle mounted in the triangle. I might regret not having the battery locked to the frame but I don't think I'd be able to trust the lock. How do others feel? In what conditions do you leave your $500 shark pack locked to your frame when you lock up your bike? I went with Luna's mighty mini, the 52v x 7Ah version with the GA cells. Sure, it's got limited range, but it would easily get me to work and back (10 mile RT). I thought I'd start with one and maybe work my way into another to extend my range. This battery is small. It would easily fit in my saddlebags, in Luna's seat bag (which I purchased), in a third party seat bag like this, maybe on my rear rack with a custom mount, or possibly I could make something to store it inside the main triangle using the two sets of bottle cage bosses on my frame. It's 6x2.75x3.25 inches -- that's pretty stealth. At 3.3 pounds it's light enough and small enough to carry along with you. At 110Wh/pound it's the most dense battery I've found. I wanted to get a feel for exactly what it would be like so I made a scale model by cutting up and re-gluing a cracker box and filling it with some padding and coins to 3.3 pounds. I know, #geekalert, but it's really given me a good idea of what it would be like.
Tools I already own
Tools and supplies I bought specifically for the build
TIP: If you don't know much about removing cranks or bottom brackets this video from Park Tool cleared it up for me.
Here's a picture of some of the tools and supplies.
Still need
Something you might need that I don’t
My background
This section I'm writing just to give other noob builders out there some idea of my background as I embark on this project. I've read a few posts from people that felt they were fooled into taking on a bigger project than they could handle after hearing that a DIY e-bike build is "easy". My hope is that this will help you calibrate your own chance for success as I go through my own build. Here goes:
Bike Prep Stage 1 -- Fenders, Rack, Remove Front Derailleur
Today I installed anAxiom Journey Rack, a set of Planet Bike Cascadia Fenders, and removed the front derailleur.
Installs for rack and fenders were easy. I had the rack already and I was pleasantly surprised to find it fit even with the disc brakes -- it's not a disc brake specific model but it was no problem at all. The fenders took some tinkering to get them to sit straight but all the spacers and long bolts I needed were supplied in the kit. Planet Bike provides a ton of extra hardware options like spacers and 45mm bolts. Here are links to pictures of the 2 instruction pages page1, page2 -- they have a complete parts inventory. Tire clearance on the back fender is a little tight mainly because I have the rack tilted back a bit -- I'm thinking about mounting my Mighty Mini battery between the rack and the seatpost/downtube rather than suspending it from the seat. With my life size model of the battery I built I can see that I'll have just enough room. We'll see how it works when the battery arrives.
Removing the front derailleur was pleasantly easy. No glitches. To break the chain I simply took the two ends of the magic link and, with my hands, pushed them together and voila, it snapped open. Here's a picture of the magic link after it had been separated.
Then I detached the cable, removed the derailleur mounting screw and, with the chain out of the way, the derailleur came off. I pulled off the handlebar grip with nothing more than slow steady pressure, no soap or anything. Then it was just a matter of loosening the brake lever and removing it so I could loosen the shifter and remove it. Really very simple and no surprises.
This is going better than expected. Hopefully it stays that way.
Fenders on, rack on, front derailleur off.
The Muirwoods donor bike has ample braze-ons and mounting points for the accessories. The back, where both the fender and rack attach, has two mounts so I didn't need to double anything up.
View from the drivetrain side
Bike Prep Stage 2 -- Clear the Bottom Bracket
I wanted to clear the underside of the bottom bracket for the motor. The cable for the rear derailleur was routed underneath the bottom bracket but veered substantially away from the down tube. I would guess about 5mm. If I left it like this I would have had to tilt the mid drive away from the down tube 5mm or more to avoid the cable and I wanted to have the motor tilted up as far as possible for clearance. This might have been overkill but I wanted to try to clear under the BB.
Here's how it looked when I bought the bike. Left to right is the rear hydraulic brake line, the front, and then the rear derailleur cables.
In this picture you can see how far the rear derailleur cable is away from the down tube.
Side angle:
In the picture below I've already removed the front derailleur and you see the brake line, rear derailleur cable, and cable guide.
Last picture before any changes. Here's how it originally finished off at the derailleur.
The solution was to buy ~5 feet of cable housing to make the entire trip from the shifter to the rear derailleur. Jason at The Hub Bike Co-op in Minneapolis was nice enough to measure out the correct length for me and he even threw in a couple metal end caps. Installation was pretty simple. I took the terminal cap off the end of the existing cable and pulled it through all the way up to the shifter removing the two existing housing segments. I then routed the cable through my new housing and reattached at the derailleur. A few strategic zip ties hold the new housing in place and I'm all set.
Prior to starting, it helped to shift into the highest gear in the rear (smallest sprocket) and then take tension off the derailleur and cable before detaching the cable -- I used a small piece of wire to pull the derailleur toward the pedal, one of the above pictures shows this.
After reassembly I thought I might have shifting issues but I had very little. I just used a couple turns of a micro adjuster and shifting is working well again.
The new housing consumed about an inch or two more cable than the previous run. I could have shortened the new housing but I still had enough cable to clamp at the derailleur. I just have less hanging out after the clamp.
The last thing was to remove the now unused plastic cable guide from the bottom bracket. I now have a clean bottom bracket just waiting for the mid drive to show up. If you look closely at the picture below you can see the new housing for the rear derailleur cable on the right of the downtube. I might move the brake line above the BB when the cranks come off but I'll wait until the motor arrives and see how it looks -- it might be fine right where it is.
Kit Arrived!
Kit looks great! Luna shipped my kit within a few days of placing the order. The delivery takes a bit longer than you might expect because the battery requires all-ground travel on UPS. All arrived in good shape but I did have a few surprises:
Just one other comment about the shipment. It was sent UPS with signature required. For me it was easiest to ask UPS to route it to the nearest UPS store which worked out great. I have a UPS account but I think you can do this with nothing more than the tracking number.
Here's a picture of the full kit that I received.
Here's a close up of the motor. You can see the bullet connectors. I've got to practice my soldering a bit as I'll need to solder on a new XT90-S connector.
And this is a picture of the battery connectors on the battery I received initially. The red/black is an Anderson connector. I was expecting the XT90-S for its anti-spark system which you can see demonstrated in this video.
So I've had a little delay but things are progressing. In the meantime I can get started on a few things like mounting the
display and throttle. I can also pull the cranks and remove the cartridge from the bottom bracket.
Bottom Bracket Open, New Battery Arrived
Pulling cranks and removing the bottom bracket cartridge was a breeze. I had the right tools and it's a new bike so things came apart just as expected. Here's some bottom bracket art. I might have to make this my avatar for the forum.
I'm thinking I'll do a future post with more about component weights. But for now let me just say that I've pulled 4.7 pounds of equipment off the bike at this point. That's made up of cranks, chainrings, bottom bracket cartridge, front derailleur, front shifter, stock rear derailleur cable housing, the small plastic cable guide that was under the BB, and the stock pedals because I got some replacements that take the pedal straps that I like. Added on so far are the new housing for the rear derailleur cable, the rack, and fenders. With the empty bottom bracket, fenders, and rack I just weighed the bike and I'm right back at 28 lbs. If I tally everything else I'm adding I'm figuring on being just shy of 44 lbs including battery. Not too bad and right in line with what I expected.
Speaking of battery, the new one arrived and has the XT90S-S connector. Awesome. I was surprised to find it has a voltage meter installed in it. Maybe one of the pictures on the website has a hint of it, but there's a clear picture of one without. At any rate, it's an interesting addition to a battery that prides itself on being small and light. The meter is probably part of what makes the battery a bit bigger than spec'd and a bit heavier. Mine came in at 3.7 pounds. Still light but significantly over the 3.3 lb advertised weight. I doubt the meter consists of the entire 0.4 lb difference from spec as the original one I was shipped weighed 3.5 lb and did not have a meter. The dimensions are also different than the spec on the website. 6 x 3.25 x 2.75 inches? Not exactly. Mine is 5.9 x 3.5 x 3.125. Not really significant, but different. Here's the kicker though. It's a really tight fit into the saddle bag I bought direct from Luna. The extra girth is significant when trying to tuck it into the bag. It does fit and I think I'll get more skilled at inserting and removing it as I do it more. So it's fine but it's kind of a pain and I feel like maybe the bag won't last as long because I kind of need to crank on it. If you ask me, I would trade the meter for the smaller size and weight savings. What good is a meter when it's tucked in a saddle bag most of the time anyway? I won't even be able to see it because it'll be in the front of the bag. Hmmm. Pffft. Just part of the fun of the DIY family I guess. :) Still, much better and safer than I could do myself and not a big deal. I’m getting really excited to get this thing assembled and running.
From looking at this picture of the XT90-S on the Hobby King site I thought the XT90-S came as a set with unique features on both the male and female side. However I was only shipped XT90 (no "s") to solder onto the controller. After some research I've come to the conclusion that one side does all the magic and using a normal XT90 on the other is fine. This thread helped: You only need the S on one side. Which side is it you ask? Male or female? Ha, that's been another small learning opportunity. It depends on if you are talking about the metal connectors or the plastic housing. The female side of the plastic housing has the metal male pins so the terms can get switched if you are not clear. It seems the standard is to talk about the metal fittings and not the plastic housing. Therefore, the female side (with the green) has the magic. I'm mating the female XT90-S (with the green) that came on the battery with a male XT90 (no "s"). If that's trouble, somebody let me know please.
Moving on, it's time to get soldering. I bought some rosin core solder to make sure I had a good quality solder as I had just a little from my original Weller kit purchased 10+ years ago. A few youtube videos later and I'm out to practice. I got pretty good. Here's one of the later and better products of my practice.
With practice out of the way it was time to get that XT90 onto the controller. For the most part it went smoothly. The tips of the XT90 pigtail had been, I think, tinned with some solder to prevent them from fraying. I wanted to mechanically join the wires first so I cut that off and stripped a little more housing. The motor I think is a 12 gauge stranded wire. The XT90 has a 10 gauge stranded but boy are the strands fine like thinner than a hair and probably 150 of 'em are need to bulk up to the 10 gauge size. It was a little touchy to deal with. I slipped on the heat shrink tubing first and then it took a little finagling to get the wires mechanically joined but I got it to a point where I was satisfied. Then I went at it to solder it together. I feel that with the super-thin strands it was harder than my practice wires to get the joint hot but I feel like I did okay. I'm sure I got solder into the majority of the joint but I also wound up with a pretty big knuckle. Maybe some flux would have helped. After it cooled I started wondering if my heat shrink was even going to make it over the knuckle. I stretched it a bit and added some dielectric grease and it slid over pretty easily. I did have one tiny strand from the XT90 wire that poked through the heat shrink. This could have been easily avoided if I had just done a final smoothing on the joint. It's a tiny hole. Overall, I'm pretty happy with it. Here's the finished product.
Next up is assembly. I'm past the most difficult parts. Shouldn't be long now.
From <https://endless-sphere.com/forums/viewtopic.php?f=1&t=20905&p=382376&hilit=+type+of+ solder+#p382376>
I don't know how experienced of a solder-er you are, but if you want to learn a thing or two this video taught me a lot about soldering - http://www.youtube.com/watch?v=I_NU2ruzyc4
From <https://lunacycle.com/bafang-bbshd-1000w-mid-drive-kit/>
Watch our video on how to re-program your 965 display to get 9 levels of pedal assist HERE
One other thing I failed to mention earlier is that I'd like the bike to be rideable without power. I knew I had to carry extra weight with me but I didn't want motor drag. BE (before electric) I would travel up to 25 miles away from home and use a combination of bike and bus/train to get around. This worked, but was a bit slow at time as city buses travel an average of around 14mph and the train about 17mph.
- Bafang BBS02 750w Mid Drive eBike KIT (Sprocket Size: 48T, Full Color Display, Bafang BBSxx Universal Thumb Throttle, Magnetic sensors to use your own brake levers, Bafang Programming Cable, Mighty Mini 52v GA, 52V Advanced 300W Ebike Charger
- Luna Cycle Mighty Mini Battery Pack Seat Case
- LUNA Wrench BBSHD and BBS02 Mid Drive Installation Tool
- $1050 including shipping
Hub vs Mid
Prebuilt vs DIY
Steel vs Aluminum
- Trek 750 Multitrack (steel, used, rim brakes)
- Trek Zektor 2 (aluminum commuter w/ disc brakes)
- Trek DS2 (aluminum, disc brakes, front shock)
- Norco Indie (aluminum, disc)
- Novara Buzz (aluminum, disc)
- Cannondale Bad Boy (aluminum, disc)
- Fuji Police Bike (aluminum, disc brakes, front shock, 26" wheels)
- Luna makes a fully assembled e-bike out of the KHS Police Bike
Disc vs Rim Brakes
Suspension or No
Flat or drop bars
Battery
Tools I already own
- Basic homeowner toolkit including several sizes of crescent wrenches, vice grips, channel locks, pliers, hammer, screwdrivers, drills, etc.
- Metric Hex wrench set
- Cheap-o socket set
- I already own a Digital Multimeter
- Soldering Iron
- Park PW-5 pedal wrench
- Bikehand bottom bracket tool
- Park Tool crank puller CWP-7
- Dielectric grease for waterproofing electrical connections
- Blue threadlocker
- Aquarium thermometer. Not sure if I'll install this but it was only $3.
- Zip ties
Still need
- C-spanner tool and bottom bracket cup wrench. I bought the Luna wrench which does both.
- (Might need/want) Moldable rubber like Sugru or Versimold. This could be useful for mounting the brake sensors or providing some cushion for the battery.
- I may need a small grindstone for an electric drill as there may be tiny bits of weld inside the BB. Or a Dremel. I'm hoping I don't need this and my BBS02 will just slide right in.
- Chain breaker if your chain doesn't have a missing link and you want to remove your front derailleur you'll need to break your chain. My chain has a missing link -- there's a tool for that too but it can be done by hand or I've seen some hacks using a wire. I'll take my chances on this and if I have trouble I may need to get a special pliers-like tool to get the missing link apart. Here is a good video that explains a lot about chains.
My background
- I've done basic bike maintenance like changing tires and adjusting brakes.
- I recently assembled a brand new single speed bike shipped to my house in a box.
- I've never pulled off cranks or a bottom bracket.
- I own a home and do much of the maintenance myself. I change out the mower deck and snowblower every year on my tractor. I've done some small remodeling projects like finishing a roughed-in bathroom but that was near the limit of my desires, abilities, and tools. I've dabbled in woodworking and have power saws, drills, and sanders.
- After reading and watching a ton of material over the last few months, with the set of tools I own, and the few purchases I've made, I'm feeling prepared to get going on the build.
- In summary, a mid-drive install is not something you do at home with "mother's toolbox". You need some special tools and knowledge. But it is within the reach of mortals -- you don't need to be a mechanic to do this. Or so I think. Time will tell. ;)
Side angle:
Kit Arrived!
- The battery had an Anderson connector rather than the XT90-S I expected. I filed a support ticket with Luna and after a few exchanges where we considered if I should switch out the connector myself (it's a bit dangerous) we decided it's best to return the battery and let them ship out the correct one. They simply shipped the wrong one. They hinted the one I got was an oddball meant for a different customer. Even dealing with a US-based vendor the shipping is still expensive in the $40-50 range because the battery has sufficient capacity to be considered hazmat. Luna was great and honored their mistake by paying shipping both ways to get me the correct battery. I hate to imagine what it would be like dealing with a Chinese company. Kudos to Luna.
- The motor came with the Bafang stock bullet connectors for connecting the battery. For some reason I expected Luna would ship the motor with a pre-installed an XT90-S connector. In hindsight this is just something I missed. Not a big deal, I just need to solder in the new connector when it arrives with the new battery. But I'll suggest to Luna that they should sell "kits" whose electric components work together without this extra step. It would be simple enough for them and it would make installing the kit just that much easier for DIY'ers. Maybe add it as an extra add-on for a small fee?
- With the confusion on the battery I got a bunch of extra connectors and things I don't think I need. I asked Luna about it and they said just keep it.
