Framed Minnesota 3 - BBSHD 100mm
    Probably the most straight forward bolt on, No shims needed, Chain line looks good... No drama to report.
    If you are looking for a fat bike build Framed is a very good choice... Though because of the lug on the seat post tube that the the front derailleur bolts on to... If I had it to do over again, I might go with the Minnesota 1.2 that has no front derailleur.
    Just waiting for the battery... 5 more days... I'll do an update
    I'm about to do the same build on a 3.0. Any long-term or short term issue to know of?
      What is the size of the back gears? I refer to size. I have a Framed Wolftrax and I am starting the build but I'm not sure what Chain Ring to buy. It's a 10 speed and it's 11-36T. Any suggestions?
        Minnesota 3.0 is the same gearing. I just got my bbshd going about 3 weeks ago and have been playing with the gearing. 44t is ok for commuting, 42 is better. 36-38t if you are doing average singletrack or light snow. 30-28t if you are going deep snow or very steep rugged singletrack. Hope that helps
          P.S.... any chainring that has long teeth like the Mighty Mini won't work with a 10 speed chain, I've tried lol. It might work with a 9s buy I do know an 8s will for sure work.
