Scott Sportster p3 2008 with Bafang BBSHD my first Build
    My latest additions to my build: Shimano steps FC-E6000 Crankset and Union CNC flat pedals.
Name:
      When I installed the e-brake sensor for hydraulic brakes I adjusted the distance between the magnet and the sensor in such a way that a slight movement of the brake lever would result in motor cutting off.
Name:
      Some times if the brake lever did not return exactly in its initial position, even for 1mm, the motor would not restart after using the brakes.
      So I had to move the magnetic field of the magnet a little bit towards the sensor. I first used a small neodymium magnet i had but the magnetic field was so strong that the sensor was not working at all.
      Finally I used an iron nut that worked perfectly and permanently glued it with epoxy.
Name:
        Last addition a SRAM PG 970 11-34 9-speed cassette
        Click image for larger version  Name:	 Views:	1 Size:	141.5 KB ID:	79777
        Click image for larger version  Name:	 Views:	1 Size:	1.30 MB ID:	79778
          The finished product:
Name:
            Great work!
            Two questions. How much did it cost? I am also interested in building a SPECIALIZED Rockhopper to e-mtb. do you think that this combo you used will be ok?
            Thank you
              Thanks for your kind response!
              I searched the net and found pics of the SPECIALIZED Rockhopper and I think that it is suitable to be converted to e-mtb.
              I also think my combo will be suitable. In the first post you can find my order from fasterbikes.eu which is a very reliable and supportive e-shop.
              You will be amazed by the power of BBSHD!
              The cost is about 1500 - 1800 Euros depending on optional accessories.
