Mongoose Hitch Fat Bike build with Luna 1000 watt motor kit
    I decided to do my first Ebike build with a cheap Fat bike and a Luna Fourth Anniversary BBSHD Mid Drive Kit Special.
    The motor kit may take a couple weeks to arrive, so I am prepping the bike while I wait
    The bike is a Mongoose Hitch steel bike.
    The frame is very solid and the wheels are very solid also.
    It's a cheap steel bike, but I am only after the Frame and the wheels for this build
    I have a bunch of nicer parts that I already had on hand that will replace the crappy steel parts that come on the bike.
    If all goes well and I like the bike after it is finished, my plan is to build up a full carbon Fat bike using my source for carbon parts, Peter at xmcarbonspeed.com.
    I have scratch build a couple full carbon MTN bikes using carbon part from Peter, but I have never had or built a Fat bike.
    So the Mongoose Hitch arrived and the build has started.
    I'll be posting build notes when I get further along
    I have 3 build videos so far on YouTube that I will link to.
    The build playlist is here
    https://www.youtube.com/playlist?lis...Iv1EMDKRdUQ7Bz
    Youtube build video #1
    Youtube build video #2
    Youtube build video #3
    Here's a list of the stuff in the Luna kit I ordered
    1 × Fourth Anniversary BBSHD Mid Drive Kit Special
    OPTIONS
    Choose Your Programming Level: Hot Rod Program (For Off Road Use Only)
    Bottom Bracket Size: 120mm (Extra Fat)
    Display Options: Luna 750c Full Color Display for BBDHD and BBS02 $45.00
    Throttle Choices: Bafang BBSxx Left Thumb Throttle $7.50
    Optional Ebrake Cut Offs: Hydraulic and Disc Brake Sensors with Cut Off (Pair) $20.00
    Battery Options: 52v Luna Wolf GA 13.5ah $250.00 (Highly Recommended)
    Upgrade Your Included Charger: Standard Barrel Charger
    Install Spacers and Helpers (Highly Recommended): Luna Install Helper - Spacer and Adapter Kit $10.00
    Add Luna Tool for Installs for only $10.00: Luna Wrench $10.00
    Add a Reccommended Gear Sensor: GearSensor for Derailers and Internal Geared Hubs $45.00
    Plus I ordered this 30 tooth chain ring
    1 × Luna Mighty-Mini 30 Tooth BBSHD ChainRing
      Build Video #4
      Converting the wheels to tubeless tires
        Video #5
        This is the final video before I start the Ebike build
        I go over all the stock parts I replaced with better parts
        The UPS tracking shows that the Luna Ebike parts will be here today
        Here's the video link
          It is up and running and it is a beast
          Taking it out now for a longer test run
          Video #6
          Shows all the Luna kit parts and the install on the fat bike
            Here's the final video on the 67 pound Big Red Fat Pig bike.
            The next build stage is transfering the Luna BBSHD motor kit over to a Full Carbon fiber Frame, fork and wheel set.
            I added a screen shot of the carbon parts I ordered
            I ordered black Shimano hubs and black spokes
            Here's the youtube video link
