This is my second ebike build. The first bike I built up was a Framed MN 2.0 that I purchased for winter trail riding up here in MN. I was so happy with how that bike turned out, but I quickly realized that I needed a bike with a suspension fork so I picked up this Motobecane with the Rockshox Bluto fork from Bikes Direct. When I received the bike, I was very impressed with the quality and looks of it. I have a BBSHD with a 52V 14A battery which has turned out to be way overkill for me. I don't think I have ever used half of the battery in one ride so I'm interested in getting something smaller and more light weight.
Here is the bike after I initially put it together (before installing the motor). Please excuse my cluttered garage in the pics.
Unfortunately I ran into some challenges during the install that I didn't experience with my last bike, and I was very impatient to get it built up so I just charged ahead without doing any research. I had clearance issues with the front derailer mount, and the motor also interfered with the rear swingarm / frame. The front derailer mount I just grinded off, no big deal. The swing arm clearance issue was not as easy. I didn't think about using spacers, and thought I could just grind some clearance out of the BBSHD in that area, which I did. I then painted it. Even after the added clearance, it was still touching the frame so I ended up purchasing some spacers from Luna. I installed one spacer and some corresponding washers the same thickness in between the bracket and motor.
After that it was time to finish up the build, including installing the gear sensor (this frame has internal cable routing), brake sensor, and installing the battery mount. I use a frame bag to help cover up the battery and give it a more discrete look.
I used 3M double stick tape for the brake sensor. The placement is tough on this one as there is not enough clearance in between the lever and the housing for the metal ring.
Chain line:
And the final product:
Chain line:
