Videos from both TIG Steel and Steel Brazing Frame Building Classes at UBI
    These are videos of mitering bicycle tubing on vertical and horizontal milling machines as well as TIG welding and brazing steel bicycle tubing. A few processes have several videos because several frames were being built and I took 3 classes.
    Here is the first one: A very experienced bicycle frame builder demonstrates how to TIG weld on thin tubing, including positioning the weldment and his hands: https://www.youtube.com/watch?v=Ejfb...ature=youtu.be
    All of the rest of the videos have sound, including a lot of classroom instruction and discussion.
    For the most part, the videos are listed here in order of decreasing file size. I uploaded 50 HD videos which was 14.2 GB.
    Using a vertical milling machine to miter a steel seat stay where it joins the seat tube: https://youtu.be/DavzTVaMKGw
      TIG welding steel chain stays to bottom bracket in an Arctos frame fixture: https://youtu.be/JuiOUqz1qsQ
        Tack welding steel dropouts in a chain stay fixture: https://youtu.be/bXlbifeJYJM
          TIG welding steel dropouts to a chain stay on a welding table: https://youtu.be/dFpJ0Ka0DCw
            Tack welding a front triangle in an Arctos frame fixture: https://youtu.be/qs4fNKCBybU
              Using a horizontal mill to miter the chain stays where they meet the bottom bracket: https://youtu.be/kj-Cho8OJ7w
                Using a vertical mill to miter a chain stay where it meets the dropout: https://youtu.be/zkcMmUqtkCs
                  Silver brazing a steel seat stay bridge: https://youtu.be/5GFttAXEUy8
                    Using a chain stay fixture and a horizontal mill to miter chain stays: https://youtu.be/Z-ILLPVo4rE
                      Using a horizontal mill to miter chain stays: https://youtu.be/DLOABxlW8ek
                        Brass brazing a steel seat tube to bottom bracket: https://youtu.be/ld_jKL3ZseU
                          Mitering a bicycle top tube on a vertical milling machine: https://youtu.be/PWnS4_i6Pe0
                            Using a vertical mill to miter a seat stay where it meets the seat tube: https://youtu.be/PWnS4_i6Pe0
                              Using a vertical mill to miter an ovalized top tube where it meets the head tube: https://youtu.be/fcDbJO-uW9g
