Drilling frames for internal wiring. Yes or No?
    Anything you can do to limit sideways motion is good. Something rigid to fill the gap between frame and battery that can take the loads off the bolts, for example. Epoxy putty, even. Not as an adhesive! But, as a spacer/mounting surface.
      Yeah I know what you mean. I think it is really rigidly on there with the battery mount solidly against the frame with no play. My battery mount has 4 mounting points and I put a bolt in each (on the Devinci, not the Townie). Because I tapped the holes, the battery mount is right against the frame and is not sitting up on top of the inserts, so there really isn't any play. I guess that is one good side to the way I installed it: it is very snug and rigid, but yes I do still realize there are other downsides to my method. I guess my install will be a good tester to see how it holds up with time, not that my results would mean anything for anyone else with a different frame/set-up/riding style, but it will be interesting none the less.
      ‚Äč
      • AndyZ
        AndyZ commented
        Yeah I would say so. Will update his thread once I know how it holds up, which may be a while since we just had a second baby :)
      • JPLabs
        JPLabs commented
        Andyz, congrats on kid 2!!!
      • AndyZ
        AndyZ commented
        Thanks JPLabs :).
      #18
      I glanced at our Townie and remembered the only reason to enlarge the hole from the now removed front derailed was to fit the connector. If one used a harness of different length where the connector wasn't in the frame, the harness would fit fine though the existing holes. Knee deep in fatbikes and snow right now.
      • AndyZ
        AndyZ commented
        Yeah that's it. One way or another the harness connectors have to get through the frame and they just don't fit :-!
      #19
      If its just the connectors. you could remove them run the cable and just remount them after.
      • AndyZ
        AndyZ commented
        Is that possible on the main BBSHD harness? I'm not speaking about the power wires to the battery, but the harness that goes to the computer, brakes, pas, etc.
      • pure_mahem
        pure_mahem commented
        I will say its beyond my skill but all things are possible with enough time and money
      • AndyZ
        AndyZ commented
        Yeah I am not skilled or patient enough for that either. I am better at using well designed plug and play stuff that gives the illusion of me having skill and patience ;).
      #20
      Check out what I just discovered, which perhaps you guys know... The harness can be dismantled. I only went as far as unscrewing the back of it. I am nervous to pull it apart because I don't know if I can get it back together. Has anyone tried this?
        For me the connector would be inside the tube. I would need another length. However if you are the first to do this you will be a Townie a Go Go hero.
        • AndyZ
          AndyZ commented
          Spray paint and a bow :).
          I have a man's bike with girl problems. I really like the matching Townie fenders. They are metal, color matched, and hug my slightly oversized tires so perfectly (I put 2.15 instead of the 2.0 max for this model). If I go with a suspension fork I have to axe the fender for a plastic one. That or I guess I could just toss the fender altogether which might not be a bad option...
        • xcnick
          xcnick commented
          I have only ridden this girls townie with a sus fork, but I don't think it is worth the effort. I would stay rigid because Trek seems to have gone rigid on all their new townies. The body float is a keeper though.
        • AndyZ
          AndyZ commented
          Yeah I really love the bodyfloat. If I didn't have a dropper on my FS I would put a bodyfloat on that too lol.
        #22
        Aside from that previous failure, I did actually discover something cool. We already know that nylon mesh looks great over the wires, but what I found out today (by reading the back of the nylon mesh package) is it looks very pro if you add some heat shrink tube to the ends of the mesh.
          I like the nylon mesh and heat shrink trick. You could cover a multitude of sins with that stuff.
          • AndyZ
            AndyZ commented
            It can definitely make an amateur look a little more pro
          • Muggsy
            Muggsy commented
            Self-sealing silicone tape works well for dressing the ends of the mesh tube, too. Even after making connections. Was much easier to use than I expected. Neat stuff.
          #24
          Nice Looking Townie. Not to rain on your parade, but why wouldnt you just learn to solder? Then you can cut the connectors off to feed them through factory frame holes. Then solder connector back on or forgo the connectors entirely? MUCH easier to solder a connector or wire than drill a proper hole without causing any spider cracks of weaknes in a good frame? Many youtube videos and it is a skill anyone in the ebike diy community should know. Lastly, as your Townie is one of the few cruiser style bikes i have seen with the BBSHD on it(other than my non townie cruiser), it would look so much nicer with the motor "in frame"......looks like u have the space. Nice looking Cruiser!!
          Doug
          • AndyZ
            AndyZ commented
            That's a sweet looking cruiser Doug!
            You are right that it would be better to run the wires through the existing holes. I just have basically zero electrical experience (although I can solder), and I was/am nervous to cut and fiddle with those little wires, especially when there are multiple wires in one cable.
            As for the BBSHD in the frame, it can't be done on this model Townie (2018 7D). I tried. Even a slight dent in the frame (like some have done on the Townie cruiser) would not cut it.
          #25
          Totally understand that frame in the way problem. I was surprised at how easy the wires are to solder. Many times you cut open a cable to find super thin strands of aluminum and have a struggle trying to solder them. But the Bafang harnesses are cake to solder with. I went with a somewhat stealth install where I removed the brake cuttoffs, but wired in a device similar to the gear sensor on the brake cable to actuate my brake lights. As well as removed factory display while keeping throttle on handlebars. SUPER easy mods that cleaned my bikes looks up a lot. Anyway, just wanted to say you have a nice frame and can do a lot with it. If my cheapo $100 frame looks good, yours can be awesome. LOL
          Doug
          • AndyZ
            AndyZ commented
            Oh good to know they aren't skinny wires. I had assumed wrong.
            Brake lights... That is super cool. Nice one.
          #26
          Originally posted by AndyZ View Post
          Nice bike! Is that yours?
          Trek Roscoe w/ BBS02, mt wheels, conti 700c tyres
            Had to revive this thread, as I have gone and done the OPPOSITE of my previous recommendation against internal wiring. My current build has most wires run internally and it looks awesome. I did have the holes professionally made with stress farrells(spelling?) brazed into the openings to prevent stress fractures. But MAN does is look good. With the battery and other electronics in the tank(hidden) the power, main harness, front/rear/brake/turn lights, horn, video cameras, EVERYTHING is internal except from the handlebars to the tank. Those will get the mesh/ heatshrink treatment. My build page hasnt been updated in a bit, but it should be entirely complete in a week or 2. So close......
