Hello everyone,
My father has a Rockrider ST530 size M ( https://www.decathlon.fr/p/velo-vtt-...8582845&c=NOIR ) that i would like to make an ebike so he can have more fun in the hills and i have some questions to ask since this would be my first ebike build !
This is the kit i would like to use ( https://fr.aliexpress.com/item/32854695403.html ), i would get the 42T 750C Bluetooth and i would most likely change the chainring for a 42T Luna Eclipse ( https://lunacycle.com/luna-eclipse-c...for-the-bbshd/ ) to get a better chain line.
By searching on Aliexpress, i found a frame bag made especially for Rockriders ST500+ it seems and it's waterproof : https://fr.aliexpress.com/item/4001088580952.html ("color" PT0713)
I also found a seller that sells specific triangle batteries for frame bags and the mesurement looks good, the V/Ah too : https://fr.aliexpress.com/item/32910373135.html
Now my questions are :
-Is everything should work together from what i chose ?
-Are those Chinese batteries reliable ?
-If not do you know a seller that make this kind of batteries with the same shapes/mesurements and V/Ah ?
-What max V/Ah battery can i run with the BBSHD it's controller without burning everything and having a good "battery life" ?
I think i'm gonna get the specific hydraulic connected brakes and the gear sensor with this too !
Thanks in advance !
Thanks in advance !
