How to Connect big triangle 14s19p 52v help
    https://e4bike.ru/page/battery-shape...28525429049071
    Hey everyone, would someone please help me with this? I can't wrap my head around about connecting it in series in a way good/proper way, the thing is I am quite an amatour when it comes to battery building, i know the concept of S-connections and P-connections but I am afraid of creating a big gap in series connection that would lead to an extensive temperature rise and voltage sag.
    Well... the battery will be use in bafang BBSHD 1000W 52V with 27 Amps of max output and I am not planning to go any further, + at majority of time I only want to draw no more then 700W for a longer period of time (430-500W more likely) ( and go nuts in the woods for short time...)
    I don't have to be strictly to the size given in the link. It should be fine with +-1cm or so.
    The cells I want to use are Samsung 35E.
    Any tips, any help is very appreciated, what size of nickel strips, any other things that I should consider? Thank you
