New Builder with Bottom bracket issues
    Hi everyone, I have a Specialized Fuse Comp (https://www.specialized.com/us/en/fu...=208517-115664). I found a couple of builders that built the exact bike to electric but I can't seem to find the right piece I need in order to fit the motor in the press fit bottom bracket (PF30).
    Here are their links: 1. https://electricbike.com/forum/forum...d-l-size-frame
    2. https://electricbike.com/forum/forum...se-comp-size-m
    Both of them mention the need to use "73mm FSA PF30 BB adapter" because the "BB30 adapter does not work with this bike even it's specs say it is BB30".
    I bought this thinking it would be what I needed (https://www.fsaproshop.com/products/...44ef31e5&_ss=r) but the motor shaft won't even fit through this so I think I bought the wrong piece.
    Below are some photo's to illustrate my problem:
    Click image for larger version  Name:	original PF BB on my bike.jpg Views:	0 Size:	1.35 MB ID:	142657
    This is the original PFBB30 for my bike with the bearing still inside there (can't really take it out without damaging the plastic).
    Click image for larger version  Name:	original PF BB on the motor side view.jpg Views:	0 Size:	1.77 MB ID:	142659
    Now that same PFBB with bearing over the BBSHD motor, the shaft or 'axle' won't fit through it.
    Click image for larger version  Name:	original PF BB on the motor.jpg Views:	0 Size:	1.85 MB ID:	142660
    Top View of the previous photo.
    Click image for larger version  Name:	Plastic piece that connects to the original BB for bike.jpg Views:	0 Size:	1.73 MB ID:	142661
    This is the plastic piece that fits onto the original BB but is removable, it does fit over the shaft of the motor.
    So I believe the bearing is too small in diameter and doesn't allow the motor to fit, which is what Lightspeed and Tofe- both found out and got some kind of adapter. As I mentioned before, I got the adapter mentioned above but I don't think that's right because it also does not fit the motor shaft through it, it's inside diamtere (ID) is too small.
    Did I misinterpret what they meant in their mention of the adapter and in fact I need to buy something else? Can someone link what I need to buy if you know? Do I need to buy an entire new BB assembly (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) Is this what I needed to buy or what they were mentioning?
    Neither of them have been active for years from what I can tell (I messaged them directly and on their posts but no response). Any help is appreciated and let me know if I missed anything crucial to mention.
    Thanks
    This is what I used for a PF41. I know its not going to work for you but maybe you can have some bushings made to fit yours. https://www.empoweredcycles.com/blog...-fit-41-89-5mm
      This should work. https://lekkie.tech/product/lekkie-pf30-bafang-adapter/
      • sittingbandar
        sittingbandar commented
        That seems to be the exact thing I need, found a local dealer here in CA that has it in stock! Thank you for finding this
