Hey everyone, newbie to e bikes here, but a big diyer of most things, and I just have a few questions I can't find specific information on.
The plan is to build my e bike in two stages, a front wheel/motor and existing batteries is stage one for cheap and immediate use without expecting good performance, and then in 6 months or so I'd like to add a separately powered mid drive and upgrade the rear wheel and brakes at that time, making it a much more useful bike.
For right now though, to get me less than a mile back and forth to work, and to keep this cheap enough to justify doing in the next week or two, at this point is looks like I will be going for a 12" scooter/bike wheel/motor, I see them everywhere "brushless gearless hub" with a green ring around the rim, it looks like they are 350w max, and capable of running on 36v.
My bigger concern at this point, is that the existing batteries I have are definitely a poor choice for an ebike because of their low capacity, but I only need them to be enough to assist me about 1 mile a day, I expect to be pedaling to start and just using the motor to cruise most of the way which is not a steep incline, but also not level.
The batteries I have are 36v, I have three batteries, a 2mah, the best I have is a 4mah from the manufacturer, which seems to last longer than the cheap eBay 6mah battery I also have.
Does anyone with a little more experience think a good 4mah 36v battery is capable of doing regular trips under 2 miles? If not, I can get more fairly cheap, and can justify getting them since they also run my lawn equipment, and although they aren't great I could get 2 more of the 6mah knockoff batteries, and maybe run the 2 or 3 6mah batteries in parallel for hopefully 10+ mah realistic capacity, and hope that's more than enough.
I'm open to any suggestions, I do plan on going with a higher voltage and much higher wattage when I upgrade the rear, but for right now I'm hoping to spend around 200 between a 12" scooter wheel ($85), and either a kit for under 100 from Amazon that appears to have everything needed for a 36v setup except for batteries, motor, or a bike, or I may try to spend half that, and hand pick a very cheap speed controller, throttle, and display.
When it comes to the different kits, motors, etc. Is everything fairly standard, or will I be hacking things up to mate the many pinned plug from a scooter wheel, to a speed controller for a bike? And other than the motor chain and sprockets vs a hub motor, are the kits for a mid drive setup the same as kits for a hub motor setup (is there any reason not to buy a complete kit for a mid mount chain drive motor, and use the controls and electronics to power a wheel hub motor(assuming the controller is for a brushless motor and the motor being used is brushless)
Thanks for any input.
PowerSet
PowerSet
