I am currently installing a used and assembled bbs02 kit setup that I recently bought, removing it from its original bicycle onto my own mountain bike. It's my first attempt at building. From install videos I've watched on these Bafang kits, I think there should have been some kind of plug-in connector along the wire that goes from the motor to the controller/battery.
But on mine now, the original installer apparently made a homemade spliced solder connection along that wire (well 2, red and white), but also first routed it through a 1" welded gap in the old bike frame before soldering, so there was zero way to remove the motor and controller from the old bike without cutting those connections, which I did.
I'd like to make a reliable and sturdy slide-in or plug type connection along this wire again, for easy future disassembly for maintenance or whatnot.
What is the best method and product for the job (waterproof, secure, and adding minimal wire resistance)? Or, should I just do a lineman splice and resolder it for the most reliable connection?
