Bbshd compatibility
    Bbshd compatibility
    Hello folks! Newbie builder here. I am about to buy this bike
    http://www.bikesdirect.com/products/...el-flatbar.htm
    and want to make sure the 68mm bbshd will fit on it. The following is all the information I could find about the bottom braket on this bike:
    BB-7420ST Cartridge Seal Oversized Bearings, JIS Square, Chromo Spindle, 68mm Shell x 113mm Spindle
    Looks like a standard threaded BB so you should be good to go.
    https://www.amazon.com/RPM-BB7420ST-.../dp/B00JSAKOWC
      Yes the 68mm BBSHD will fit. Like all these builds until you pull the cranks off and start the build unless someone else has a documented build then you do not know how hard a build its going to be. It looks fairly straight forward though.
