What's up with the BBSHD cranks?
    They say 8fun AC on the inside of them which is weird, but I guess that is ok. My main question is why I can't get this left crank to get closer to the motor? The other one looks fine, but the left one looks like it is bent a bit and I can't seem to pound it in tight enough? Time for aftermarket cranks? That's assuming I can pull em off....
Name:
Name:
Name:
    Thanks.
    I figured they are different because the motor does not mount symmetrically.
    Could this be to help even out the position of the left and right side pedals???
      Isn't this the reason why they are left and right crankarm? I think in my manual it said explicitly they were different and I should watch which is L or R. Is the distance from pedal to frame same on both sides? If it is I would assume everything is ok.
        The threads for pedals are opposite: left-hand threads for right crank / right-hand threads for left crank.
          This is an old thread, but I would like to add some Info, probably known to most people already.
          The motor doesn't mount symetrically indeed. In Your case You had the needed offset crankarm inclusive, but I had identical crankarms with the same offset (left and right side of course). After a while I noticed I had about 15mm on crankarm to frame distance on the right side, but only 5mm on the left. It still cleared the chainstays, but You know, once seen it can't be unseen and You want it fixed. I was waiting to have the extra cash needed to order an offset Bafang crankarm, which in my case would be expensive, since I live in Europe.
          I was looking for some bike parts in my cellar, when I stumbled upon the Shimano cranks from a MTB donor bike I had in pieces. As I had the left crankarm in my hand, ready to throw it to the side, I noticed that it had a pretty big offset. It had the same length (170mm). I took it upstairs to ompare to the original and it cleared the chainstays indeed much better.
