Thanks for the follow up! Great! What chairing are you using? when I tried the Luna Eclipse, it hit the chainstay on my 2017 Sturgis. I narrowed mine to work, but otherwise would have needed to shim the motor a few mm further right. With few threads, sounds like maybe you won't have that option?
Motobecane Sturgis 2018 fit with BBSHD 100mm ?
I was wanting to fit a 52T chainring using the luna spider adaptor. After realizing that was excessive, i switched to the original bafang 46t and have since switched to a 39t on the luna spider. Since i witched to the 39t i was able to get the motor in closer to the bicycle frame and have more threads exposed on the non-drive side so the installation is better secured and more centered.
