Hi total noob here to ebikes and I have not really touched a bike much since I was 16(43 now). I have a few questions. I just got A Boris FS NX last night in a 15" frame(I have a short legs) and I'm planning on putting a BBSHD in it.
Cheapest bike on bikes direct right now with a Bluto fork.
I have read all the threads I can find on the 170 mm rear geometry Boris frames and most have used the 100 mm kit. I only read about one that was able to use the lock nut/beauty ring and it only had 3 mm of spacer to clear the chainstay. Most builds seem to use 6 mm or more for the motor to clear and don't have enough thread to put the ring on. What are the negatives to using the 120 mm BBSHD on this 100mm BB bike?
Am I going to need an excessive amount of spacers to get the chain line decent? Should I look at offset crank arms? Is the 100 mm a better bet?
Right now I'm thinking about using either a 36 tooth Luna one or a 40 tooth one piece Luna Eclipse. Both have an 8 mm backspacing but I'm unsure which would be best for the mix of terrain I'm gonna use it in. The bike has a Sram 11-42T-11spd cassette and a 30 tooth front. After riding today there is nothing I would use the last 2 or 3 cogs on locally. Where I live its mostly flat but I do plan to take the bike to do jeep, double, and single track in the mountains in Colorado and Arkansas. I may also use it to pull a trailer with my dog or small game. I am currently leaning towards the 40 tooth is this a mistake?
Kinda wish I would have got the 17" frame now and just dealt with the potential discomfort. I was hoping to use a 17.1 ah triangle pack from EM3EV but it wont fit. Sadly a Shark wont either.Here is a pic with a template of the Wolf in the triangle. 1/4-3/8" more clearance and it would probably fit.
I think I'm gonna go with a wolf pack mounted on the bottom of the downtube.
