Hello,
Was thinking about making a solar trailer for an ebike, would use a couple of cells and a boost converter. The question is do you plug the boosted solar power to the charge port of the battery or do you plug it in directly to the motor power alongside the battery? As I understand constant charging and re-charging of the battery will deplete it quite fast?
Or is it just better to find a small gas generator?
