ISCG05 Removal
    ISCG05 Removal
    I don't know how common these are but my frame had one and needed to be removed to fit the BBSHD.
    These are a mount for a sprocket guard. This one was tack welded to the outside diameter of the bottom bracket. My bottom bracket was 73 mm before I took it off and is still 73 mm.
    This was easy to remove with a cut-off wheel. I ground down the weld most of they way then tapped it off with a hammer. May take a couple times of little by little so you don't damage the BB.
    Nice,
    "Make way!"
      awesome thanks for that.
