Bullseye Monster XE
    Bullseye Monster XE
    I'm considering this bike to do some scouting and some hunting in a 20,000 acre area. 750W is definitely as high as I need or am able to go. I want to keep my cost low. I am definitely a bike enthusiast but my Giant XTC can't handle thiese conditions at all. I'm not 30 any more so I like the idea of having some help when and if I need it pedaling. This are is very wet. Here are large areas of flooded woods large puddles Not really very hilly here in FL actually very flat. So I am concerned about the connectors and I don't mind having to replace something every coue years but I don't want to be left stranded. In some areas it will be 6"-10"deep.
    I have read countless reviews on ebikes but not anything on this one.. It seems pretty good for the price.
    I would consider buying a kit and doing it myself, if I could save money or get a better finished product by putting in the same amount as this one. I appreciate any advice or suggestions.
    I have listed the details and the model from the Bikes Direct. It's the Bullseye Monster XE
    Thanks!
    These are the details and the link.
    Fhttp://www.bikesdirect.com/products/gravity/ebikes/electric-bikes-fat-bikes-bullseye-monster-xe-ebikes.htmrame
    ADVANCED HYDROFORMED ALLOY 6061 FRAME, W/DISC MOUNT, TIG WELD, replaceable rear derailleur hanger, H2O bosses, T/T-35MM, S/T-31.8MM, D/T-44M, Rear Rack Seatstay Brazeons, 190mm symmetrical rear, Tapered HT
    Fork FRONT SUSPENSION, 120MM RST RENEGADE TNL COIL W/THRU AXLE, ALLOY BLACK, Tapered Steerer Tube, 150mm OLN
    Crankset SAMOX 32T ALLOY BKx175MM ALLOY BLACK CRANK
    Bottom Bracket SAMOX EB2403 120x1.37
    Pedals VP BLACK PLASTIC BODY W/STEEL BLACK CAGE
    Front Derailleur n/a
    Rear Derailleur SRAM RD-GX BLACK
    Shifters SRAM SL-GX 10-SP ALLOY BLACK
    Cassette SRAM PG-1030 11-36T
    Chain KMC E11S NPBK
    Hubs
    F/HUB : KT-M9CF ALLOY BLACK W/KT204B ALLOY BLACK 150mm THRUAXLEQR.
    Spokes 14G STEEL BLACK W/BRASS NIPPLE
    Rims 26"x32H HJC P-80 WIDTH 80MM W/BIG HOLES, ALLOY BLACK
    Tires/Tubes 26"x4.25 VEE RUBBER BULLDOZER, 72TPI TIRE
    Brakes/Levers BRAKE: SHIMANO M365 HYDRAULIC DISC BRAKE W/SM-RT56S 160MM ROTOR.
    LEVER: SHIMANO BL-M365 ALLOY BLACK
    Headset VP BLACK W/ ALLOY BLACK CAP
    Handlebar KALLOY LowRise W:700MMx9 DEGREES, ALLOY BLACK
    Stem KALLOY EXT:90MM(14"~16")/110MM(18"~22")x7 DEGREES, ALLOY BLACK
    Tape/Grip WTB BLACK/GRAY KRATON
    Saddle WTB SPEED V SPORT SE, BLACK
    Seat Post Micro Adjust 400MM, ALLOY BLACK aluminum
    Seat Post Clamp ALLOY SEAT CLAMP
    Sizes See pull down
    EBike DriveTrain REAR MOTOR : BAFANG 750W/RATED VOLTAGE 48V.
    HMI : BAFANG ADVANCED LCD/48V/5 POWER LEVELS
    SPEED SENSOR : BAFANG SR.PA01.12.S. .
    CONTROLLER : BAFANG CR.S107.1000.SN 48V/SPEED MAX 32km/h.
    THROTTLE CONTROL : BAFANG 130X WITH CONNECTOR EB.1T2.AX. LEFT SIDE
    BATTERY/CHARGER : PHYLION SF-06 SMART 48V/11.6Ah (557WH)
