Sur Ron LBX Brake and Turn Lights
    I'd like to wire brake lights and turn signals but really am lost. I've seen a couple posts but mainly people just show their setups and the products they used. I haven't seen anything in the way of how it actually all hooks ups. I get that you would use the brake sensors as the way to signal the brake light, but how does that work? Do you disconnect the sensor lead from the wiring harness and wire into that? Just not sure how it works. For turn signals, where do you get the 12v power and how do you make it flash? I realize many responses will be "get someone to do it for you" but for now let's assume I don't have someone to do it for me.
    This kind of switch & signals will work, (the signals auto-flash). I suggest you tap the headlight circuit for power. I don't know if the lever switches repurposed will last on a brake light circuit, but it's no sin to try it. The independent brake/taillight is quite bright. Yes, some diy electrical skills will be necessary.
    https://www.ebay.com/itm/7-8-22mm-Al...item5d71fb3dc6
    https://www.ebay.com/itm/4Pcs-Motorc...72.m2749.l2649
    https://www.ebay.com/itm/LED-Bicycle...53.m1438.l2649
      This thread as some wiring details
      https://www.endless-sphere.com/forum...f=28&p=1488219
