anyone use a direct mount stem for the RST? if so, do you mind sharing your thoughts and photos?
Direct Mount Stem
I don't know if you like, but I found this direct mount.
https://www.ebay.com/itm/KALLOY-Dire...IAAOSwBLlVQz9i
Looks better now
You're going to need spacers for the steer tube since you are taking the existing stem out of the stack. Alternatively you can cut the steer tube down. Link to a cheap spacer set that I used is below.
You do not NEED spacers for the direct mount stem itself unless you want to increase the height. If you are using the stock bars you'll probably want some spacers. If you are swapping out to riser bars, maybe not.
Steer tube spacers...
Find many great new & used options and get the best deals for Carbon spacer Stem Spacer1-1/8 inch 4 pcs of 5mm/10mm/15mm/20mm Headset Spacers at the best online prices at eBay! Free shipping for many products!
Direct Mount stem spacers...I'd buy from these guys as they are supporting the Sur Ron Community...
Hope that helps.
- Likes 3
Questions regarding DM stems. Are there different bolt patterns for different forks? Looking to use one on a DNM fork but when looking for spacers from North Shore they have this listed at bottom of page..
These spacers are designed to work with mountain bike DH forks such as the Boxxer and the Fox 40. These spacers will not work with forks such as the DNM Volcano USD-8C.
Went to contact them but my phone wont allow me to call Canada ad they dont have another contact option for questions.
Anyone know about these parts and fitment?
Originally posted by rider400 View PostQuestions regarding DM stems. Are there different bolt patterns for different forks? Looking to use one on a DNM fork but when looking for spacers from North Shore they have this listed at bottom of page..
