Dorado Pro or Bomber 58
Thanks for the intel! I do have the upgraded Luna headset now. I deformed (ruined) the original lower bearing race while removing it so I think I might need another new headset just for the lower race. The original lower race took a lot of prying to get it off and I don't have a special tool to remove it. At least the headset is reasonable at 50 bucks.
- 1 like
The boost and non-boost downhill spec are both 20x110mm front axle. That is a little confusing because for single crown forks non-boost has a 100 mm axle. Functionally, the only difference is the position of the brake caliper/disk. See the image. Does anyone know if a special caliper adapter is required or is it within the adjustability range of the standard post mount?1 Photo
- 1 like
